if your goin agp spend $90 and get a 9800pro
http://www.actbuy.com/details.asp?item=AT10030-3
1. You won't see a performance difference between 512mb and 1gb unless you do alot of gaming.erosion said:So I guess I'm looking for:
1. 1GB ram
2. Fast AMD Processor since that what a lot of people seem to perfer (i'm going to run stock)
3. Decent vid card (not the best of the best, but decent nuntheless, maybe a ATI Radeon or GeForce?)
4. Two HDs (Main HD: 40GBish, Slave HD: 100GB or 120GB(if it's not much more) and if it's easy enough I can stick my current 80GB slave HD in there aswell giving me 3 HDs)
5. CD/DVD Burner (I burn a lot of CDs)
6. CD/DVD ROM
7. Floopy Drive
8. Ethernet Thing (Cable)
9. Decent speakers + sub (i listen to a lot of music)
10. Optic Mouse (with the scrolling wheel in the middle)
11. Internet Keyboard
12. Motherboard (I'd like 4+ USBs, If not I could just get a USB hub.. I have a lot of stuff that uses USB's)
13. Sound card? (Unless that comes with the motherboard?)
You should purchase a case and power supply as units of individual merit. NEVER settle for the power supply that is included with any particular case. Generic power supplies are complete junk and there are certain brands that perform worse than others.- Case - I'm not sure what Watt I should get but as it has good cooling (fans) I have my computer on almost 24/7.
Heres a few cases I liked, Not sure if they will work with what ever I get..
Yes, those ports plug into the motherboard.A lot of the cases I see have like more usb ports/headphone jacks on the front.. Does that stuff come with the case?
The motherboard comes with the majority of the cables you need.Also any other nessary stuff, ie: wires, hardware I'm forgetting etc...
If the router has an integrated switch or is plugged into one and already setup then all you need is an ethernet cable to go from your new computer to the switch itself.Also, This comp will be routered. So I don't know if anything else is needed for that. (I don't know crap about routers)
Current price total is $827 (because you wanted a more beautiful case)I think I gave you guys a better idea of what I'm looking for heh... Think something reasionable could be built for less then $1,000 (maybe even less then $800)? if I have to cut some costs I could just forget about buying two harddrives and just buy one and use my slave hd from my current comp.
Captain Slug said:Is there any particular reason you're going with TigerDirect?
Captain Slug said:1. You won't see a performance difference between 512mb and 1gb unless you do alot of gaming.
2. I added the fastest one within your budget to my list
3. A Geforce 6600 can run anything at any resolution at medium detail or better depending on the game
4. The list now includes a 40gb main hard drive and a 120gb secondary. Your 80gb hard drive (which I'm assuming is IDE) can go on the same cable (included) as the CD/DVD combo drive
5. Included
6. Is there some reason you need another drive? You only need one drive to copy or burn CDs.
7. Those are pretty useless but I added it anyways
8. Are you saying you need an ethernet cable or an ethernet jack? The motherboard includes ethernet so it's ready for broadband
9. included
10. also included
11. also included
12. The motherboard includes 8 ports
13. integrated into motherboard[/url]
Captain Slug said:Current price total is $827 (because you wanted a more beautiful case)
http://www.newegg.com/OldVersion/ap...price=&maxprice=&mfrcode=0&DEPA=0&InnerCata=7
And if you want to shop around newegg for a case yourself check their selection of over 200 models: http://www.newegg.com/OldVersion/app/viewproduct.asp?submit=list&catalog=7&DEPA=0
Captain Slug said:List link (same URL as before): http://secure.newegg.com/Oldversion...w.asp?position=HISTORY&submit=VIEW&ID=1548004
I'm on AIM now if you have any questions
1. The case is ATX, The motherboard is ATX. The hole pattern is standard. If you pick an ATX motherboard, you have to pick an ATX sized case. If you pick a Micro ATX motherboard (which is slightly smaller) you can pick Micro ATX or ATX sized cases.erosion said:hmm I nocited the holes on the platething on the back of the case dont appear to line up with the motherboard...
http://images10.newegg.com/productimage/11-133-142-10.JPG
http://images10.newegg.com/productimage/13-136-147-07.JPG
edit: I started looking at other cases to see, and none of the cases I seen seem to match the motherboard sockets
edit #2: I just noticed the motherboard comes with a plate thing, Witch I'm guessing fits where the other one would go
http://images10.newegg.com/productimage/13-136-147-04.JPG heh, that was one of my moments of retardism I noticed it didnt line up but didn't notice the plate that fits heh. go me go me.
Onboard sound is way better than it used to be and in most cases performs the same as the majority of PCI sound cards. The advantage of a PCI sound card nowadays is negligable for playback and would really only be needed if your were either having problems with the onboard sound, or needed to do high-quality recording and mixing.UPCguy23 said:Oh.....side note....what do you guys think about sound? He's wanting speakers with a sub, and most decent motherboards have good sound cards built in, but if he's like into music or anything, should he look into a pci sound card?
UPCguy23 said:it would probably be just fine unless someone is just a pure sound junkie
I shuffled the parts around a little to make the machine more future-proof and the price went up less than I expected it to. The total is now $840, but you're getting a faster system over-all for what you're planning to use it for.erosion said:Captain Slug, What do you think of upcguy's suggestions above?
Sure it's fater, but it's also louder. 40gb is way more than enough space for an operating system and main program hard drive. You can install all of your games and keep your documents on the 120gb hard drive for safety and speed.also.. I showed the setup you picked at another forum to see what they'd think... over all they think its a pretty good setup for the price. One person suggested that I should get two of these 80gb Hd insted of the 120 and 40
http://www.newegg.com/OldVersion/app/ViewProductDesc.asp?description=22-148-040&depa=1
They over all its a few bucks cheaper and its the same ammout of space and he said should run faster..
The new list has considerably faster Processor, Motherboard, and RAMthen he suggested getting this processor with the few bucks I saved on the Hd's http://www.newegg.com/OldVersion/app/viewproductdesc.asp?description=19-103-486&DEPA=1
he said it should give me the best proformance from the video card you picked
Captain Slug said:the price difference is only $30 from the previous list.
