- May 15, 2006
- Thread Starter
- #101
I'll have to decide that once I get itApart from painting the case what other mods you got planned thid?
Correct, mods first then paintDoesn't it work better if you mod then paint?
I mean...why kill a nice paint job?
1 for now, I'll either add another HDD bay or just a 120mm fan...this thing has tons alreadyVery nice .. Although I do think you need some 120x38 fans on that TRUE to make it look even beastier ... You got any fans mouted at the front?
I will take a guess and say...no.Could that case fit an MCR320, 4 HDDs, and a DVD drive in front?
With the armor, I could have the control panel, dvd drive and a fan controller while keeping the 120.3 in the 5.25 bays. This is much less than that. A 120.2 doesn't even look like it would fit.
What is the major difference between the Armor and the Armor PLUS that caused you to love the former and hate the latter? . . . I'm just wondering because I'm in the process of setting up a new case and I decided to go with the Armor PLUS because of all the room, the ten PCI slots, seven 5.25" bays, five HDD bays, five 140mm fans, etc. . . . The only thing I don't care for is the flaps on the front of the case but the old Armor had that too. . . . So I'm just wondering what turned you off about the new Armor PLUS?[*]Thermaltake Armor (loved this case when I had it)
[*]Thermaltake Armor PLUS (HATE, DO NOT WANT, uglier than sin)
Well, the 10 pounds of extra plastic they taped to the top and front, the side fan is worthless, placement of the hard drives...many many things. Overall, I just don't like the case. They included some nice features, but I think they overdid it.Hey thideras,
I just had a quick question from your original post. . . .What is the major difference between the Armor and the Armor PLUS that caused you to love the former and hate the latter? . . . I'm just wondering because I'm in the process of setting up a new case and I decided to go with the Armor PLUS because of all the room, the ten PCI slots, seven 5.25" bays, five HDD bays, five 140mm fans, etc. . . . The only thing I don't care for is the flaps on the front of the case but the old Armor had that too. . . . So I'm just wondering what turned you off about the new Armor PLUS?
I was assuming that you used the included hard drive bay
Ooohhh....I like it...I'll have to tinkerI think the hard drive bay they include is pretty crap so I too used 5.25 to 3.5 adapters for my 3 HDDs, I've then got a pair of fans in the front of mine as intake, moving air over the drives .. You can get 5.25" bay 120mm fan bays and with Yate Loons thing 20mm thick fans you can fit then in with the drives as well .. I agree with this being a case that's hard to improve tho .. I love mine
I know exactly what you mean. I had the armor and you could basically use ALL the space inside of it. This one is more rounded than anything, so it seems much larger than it really is. It isn't small though, not by any meansNice case, and I do like the aggressive look of the front n all, but it there really that much room in there? From the pics, it just doesn't look like as huge a case as everyone makes it out to be, but more of the mid-tower sizes.
I guess I'm just too used to the a71.
