Intel Skylake Comes in 2015, Brings DDR4 and PCI-E 4.0
Some details regarding the successor to upcoming Broadwell CPUs, codenamed Skylake, have emerged with the leak of an alleged presentation slide. Intel’s future CPUs are to feature an all new architecture and a new socket, moving from 1150. Additionally, it will bring DDR4 memory support to the mainstream market, as well as PCI-E 4.0 for increased graphics and system bandwidth.
Intel Roadmap for HPC - Image Courtesy: Xbit Labs
Intel Roadmap for HPC – Image Courtesy: Xbit Labs
In addition to a new architecture and support for new memory and I/O bus, Skylake should bring new instructions to the table. The AVX3.2 instruction set will build on current AVX2 and will bring enhanced performance for optimized programs. Furthermore, the rumor wants Skylake could implement some level of memory unification for CPU and built-in GPU, just like AMD hUMA (heterogeneous Unified Memory Architecture) that will debut later this year. Memory unification should simplify the use of graphics processing engines for general purpose applications.
Intel’s Skylake parts are set to be built on 14nm, a manufacturing process that is the new logical step after the 22nm node which is being used for a second series of CPUs with Haswell. The new process is expected to debut in 2014 with a possible Haswell refresh. It will therefore be a mature process by the time Intel introduces its new Skylake architecture, moving along with the company’s “tick-tock” product strategy.
Source: Xbit Labs
dostov
Loading new replies...
Avatar of txus.palacios
txus.palacios
3,934 messages 0 likes
I think there is a typo there. It should say AVX3.2 instead of AVX2, and AVX2 instead of AVX, as Haswell already has AVX2 support.
The AVX2 instruction set will build on current AVX
Reply Like
Avatar of dostov
dostov
Overclockers.com Reporter
601 messages 0 likes
You're right, it is a typo. Skylake will implement AVX3.2 instruction set.
Reply Like
Avatar of Bobnova
Bobnova
Senior Member
20,964 messages 1 likes
Slide has errors in it, lol.
PCIe3 came with IB, SB was all PCIe2.
EDIT:
And Haswell (Note: not Haswell-E) as DDR4.
Reply Like
Avatar of MattNo5ss
MattNo5ss
5up3r m0d3r4t0r
8,808 messages 0 likes
SB-E has PCIe3.0
Reply Like
Avatar of Bobnova
Bobnova
Senior Member
I can only find two SB-E+Titan/7970 results on HWBot that say PCIe 3.0, everything else is 2.0.
I was under the impression that Intel initially planned 3.0 and dropped to 2.0 at release.
Intel says 2.0: 3960x 3930k
Reply Like
Avatar of BigSurprise
BigSurprise
252 messages 0 likes
EDIT:
It does show Haswell under 2014, so maybe they did mean Haswell-E? :shrug:
Reply Like
Avatar of hokiealumnus
hokiealumnus
Water Cooled Moderator
16,561 messages 25 likes
SNB-E was capable of running PCIe 3.0, but not specifically certified for PCIe 3.0 by the PCI Special Interest Group in time for its release. So while it couldn't technically be called PCIe 3.0, it's basically running PCIe 3.0.
Clear as mud?
Reply Like
Avatar of Bobnova
Bobnova
Senior Member
Looking at it again, it's talking Xeons, not desktop.
That's what makes the difference, SB-E Xeons are rated for PCIe3.
Sooooo, this slide means nothing for desktop use.
Reply Like
Avatar of MattNo5ss
MattNo5ss
5up3r m0d3r4t0r
PCIe 3.0 couldn't be properly tested for compliance when SB-E was released. So Intel couldn't say/market that SB-E was PCIe3.0 compliant, although the CPU has native PCIe3.0 support.
Some desktop X79 motherboards allow PCIe3.0.
Reply Like
Avatar of Bobnova
Bobnova
Senior Member
EVGA does on some BIOS, looking at HWBot. TiN and Vince have PCIe. Nobody else I ran across.
I'm surprised Intel hasn't gone back and gotten it certified.
Reply Like
