ADATA Gammix S11 480GB M.2 NVMe SSD Review
Today we get an opportunity to look at another M.2 NVMe based SSD in the ADATA Gammix S11. The Gammix series of products are typically part of a higher performance line and the Gammix S11 drive is no different. The modules are able to reach speeds up to 3200MB/s sequential reads and 1700 MB/s on writes which, on paper, places it up there with other enthusiast level drives.
The Gammix S11 shares the same internals and specifications with the SX8200 but differ on a price level with the S11 costing a bit more. The main difference between the two are the included heat spreader on the S11 and branding, but under the hood contain the same bits including the Silicon Motion SM2262 controller and Micron 2nd generation 3D TLC NAND. The S11 should run a bit cooler with the heatsink and performance should be in the same ballpark. We were able to put the drive through our testing suite and see if the paper specs match up with actual results. Read on to see how the Gammix S11 fared in our testing.
Specifications and Features
The ADATA Gammix drives comes in three capacities – 240 GB, 480 GB, and 960 GB with performance scaling up as the capacity increases. For example, the 240 GB drive is rated at 3200/1100 MB/s Reads/Writes with 200K/240K IOPS while the 480 GB and 860 GB models run 3200/1700 MB/s with 310K/280K IOPS. The S11 outperforms the S10/SX8000 from last year due to the new internals.
Generationally, the S11 differs from the S10 in both the controller used as well as the NAND. The XPG Gammix S11 uses the latest Silicon Motion SM2262 controller and pairs it with 2nd generation 64-layer Micron 3D TLC NAND. This combination of controller and NAND improves performance significantly over the outgoing SM2260 based models (Gammix S10, XPG SX7000/8000). Also updated is the NVMe protocol moving from 1.2 to 1.3.
Unlike our previous review on the Toshiba OCZ RC100, the ADATA Gammix drives all come in a 2280 size and use both sides of the PCB. On one side are the storage modules, a NANYA DRAM module (512MB total through 2x 2Gb ICs), and the controller, while the other side has another DRAM module and storage modules.
In addition to the new internals, the drive includes an already attached heatsink which isn’t just there for aesthetics. The new heatsink is said to drop temperatures by about 10°C compared to M.2 SSDs without a heatsink. If that isn’t good enough, ADATA also offers (separately) the XPG Storm heatsink which they say is the first M.2 2280 SSD add-on heatsink on the market. It is made of aluminum with a plastic shroud and incorporates a tiny fan for active cooling. The device also includes three RGB LEDs under the shroud and is compatible with RGB lighting control apps from the major motherboard manufacturers.
On the software side of things, the Gammix S11 supports Low-Density Parity Check (LDPC) error correcting technology ADATA says can detect and fix a wider range of data errors for more accurate data transfers and a longer SSD lifespan. In addition, the drive supports RAID Engine and Data Shaping they say ensures data integrity and delivers an extended SSD lifespan for longer-lasting stability.
ADATA Gammix S11 480GB M.2 NVMe SSD Specifications
Capacity240 GB, 480 GB, 960 GB
Interface NVMe 1.3 PCIe 3.0 x4
ControllerSilicon Motion SM2262
FlashMicron 64L 3D TLC
Form FactorDouble-sided M.2 2280 B + M Key
Dimensions (LxWxH)80 x 22 x 3.5 mm
DRAM Cache512MB
Sequential Read/Write SpeedsRead: 3150-3200 MB/s
Write: 1100-1700 MB/s
4KB Random Read / Write (QD32)200k-310k IOPS
240k-280k IOPS
Active / Idle Power.33 W (typical) /  .14 mW (slumber)
Service & Support5 Years
Endurance / MTBF960 GB – 640 TBW
480 GB – 320 TBW
240 GB – 160 TBW
2,000,000 MTBF
Pricing960 GB – $279.99
480 GB – $154.99
240 GB – $99.99
ADATA Storm Heatsink – $35.99
Packaging/Product Tour
Our first glimpse of the retail packaging for both the M.2 PCIe SSD and the Storm heatsink show they follow the XPG theme with black packaging along with a picture of the product in the middle. Adorned around the edges are mentions of capacities and features while on the Storm box its RGB lighting compatibility is listed.
From the slideshow above, users are able to see the packaging for the S11 has a flip top lid exposing the drive as well as listing features on the flap. The 2280 size drive fits snug in form fitting foam inside the packaging to prevent shipping damage. The Storm is packed similarly sitting securely in cardboard with the included accessories (power leads, screw, RGB control wire).
Our first look at the drive shows its heat spreader attached and looking good hiding the ICs while flipping it over, exposes a DRAM cache chip and hidden under the label, more ADATA storage modules. After taking the heatsink off (attached with a thermal pad only) we are able to see the controller, DRAM cache, and NAND.
The pictures above are close-ups of the Silicon Motion 2262 controller, ADATA labeled 2nd Generation 64-layer 3d TLC NAND, as well as the NANYA DRAM Cache IC which weighs in at 2Gb each for a total of 512MB of DRAM cache capabilities.
The slideshow above shows pictures of the Storm heatsink base showing the thermal pad as well as the device’s RGB LEDs in action.
Software
ADATA, like other SSD manufacturers, also include access to free software to get the status of the drive in the system. ADATA’s is called SSD ToolBox.
The SSD Toolbox is a complete utility used to monitor as well as optimize the drive. The colorful software is able to run diagnostics (both a quick and ‘full’ diagnostic), set temperature and capacity alerts, Secure Erase capabilities, as well as system optimizations which include adjusting settings for Superfetch, Prefetch, and automatic defragmentation abilities. Overall it keeps an eye on the drive and will help set up your operating system for peak performance with the drive. In my limited use with the software, it worked as described.
Test System and Test Methods
We install the drive as a secondary device on the test system and run the listed benchmarks against it. While typically, many will use these drives as system drives, the test machines can be different as will people’s OS implementation in the first place, so we try to isolate as many variables as possible in an effort to have the results as repeatable as possible with any reviewer who may test drives.
Below are the tests we run with a brief description.
  • Crystal Disk Mark – Run at Default Settings (5 Passes)
  • AS SSD – Run at Default Settings
  • ATTO – Run at Default Settings except for the QD Set to 10
  • Anvil Storage Utility Benchmark – Default Settings
Test System Components
MotherboardASUS ROG Maximus X Apex
CPUIntel i7 8700K
CPU CoolerEVGA CLC 240
Memory2×8 GB G.Skill Trident Z 3200 MHz CL15-15-15-35
SSDToshiba OCZ TR200 480 GB (OS), Toshiba OCZ RC100 480GB
Power SupplyEVGA 750W G3
Video CardAMD R7 250
A special thanks goes out to EVGA for providing the CLC 240 CPU Cooler and 750W G3 Power Supply to cool and power the system, G.Skill for the Trident Z DRAM, and Toshiba OCZ for the 480GB TR200 SSDs storage running the OS, benchmarks, and games. With our partners helping out, we are able to build matching test systems to mitigate any differences found between using different hardware. This allows for multiple reviewers in different locations to use the same test system and compare results between reviewers minimizing system variance.
Performance
CrystalDiskMark
Crystal Disk Mark – Reads
Crystal Disk Mark – Writes
In our first test, Crystal Disk Mark (CDM) Reads, the S11 performed well in the high queue depth reads marking the fastest drive we have tested so far at 3179 MB/s but comes back down to the middle of the pack results with lower queue depths. 4K reads lead the pack by a fair margin here and show middling performance on writes with a larger queue depth.
On the writes side of CDM, again we see solid performance at a higher queue depth coming in 2nd place by a slim margin and reaching its specified read speeds. Lower queue depth reads also performed well with a middle of the pack result again. 4K writes at a deep and shallow queue depth performed admirably settling in the middle of the pack.
AS SSD
AS SSD – Reads
AS SSD – Writes
In AS SSD, the S11 really shined here beating out the competition across the board in reads and writes no matter the queue depth. This is the first drive we have tested which broke the 50 MB/s mark with a 63 MB/s reads in 4K file sizes. While sequential throughput is important, the vast majority of files are much smaller so 4K performance is an important metric on how well the drives perform on a daily basis. Outside of the 4K results, one will notice the similar performance here between the SX8200 and S11.
AS SSD – Access Times
AS SSD – Overall Score
Access times in AS SSD were also the fastest we tested which leads to the overall score. The ADATA S Gammix S11 managed to score higher than all drives we have tested here with a score of 3846, barely beating out its SX8200 twin.
ATTO
ATTO – Reads
ATTO – Writes
In ATTO, the Gammix S11 performs quite admirably, leading the SX8200 and the Patriot Hellfire by a small margin in reads. Writes, on the other hand, go to the Hellfire, with the S11 and SX8200 performing essentially the same. Nothing out of the ordinary in ATTO testing.
In our Anvil Storage Utility results, the S11 scored 13,279 which is the fastest result we have seen so far.
Conclusion
The ADATA Gammix S11 performed well during our testing trading blows with its less expensive twin the SX8200 ($140 @ Newegg) and the Patriot Hellfire, both of which we reviewed (SX8200 and Patriot Hellfire) here at Overclockers.com. The S11 proved itself to have enthusiast level performance (but not the best), while not asking for a premium compared to other drives in the market (Samsung 970 Pro for $198. Though when looking at the Samsung 970 Evo for $155, it is currently priced a bit less and, on paper, outperforms it. It does not come with a passive heatsink, however. To that end, there is a lot of competition in the market for this size and speed M.2 NVMe drive.
Along those lines, ADATA offers the Storm active heatsink which will fit on any drives. For an additional $28 on Amazon, users are able to add a heatsink that will keep the M.2 drive underneath cool and help prevent any throttling due to thermal conditions. The Storm heatsink at full tilt was audible over the video card and system fans but a simple adjustment and that noise of the tiny fan was mixed in with other ambient system noises. A potential drawback on using this item is that it will not fit under a video card as it sits about 1/2″ above the PCIe slots. That out of the way, the Storm kept temperatures around 9°C cooler with the fan on low than with the heatsink alone keeping it well under the throttling point. If the plan is to use the drive heavily, this can be a good add-on to prevent potential throttling.
The ADATA Gammix S11 brought to the table its second generation 64-layer 3D TLC NAND along with the new Silicon Motion SM2262 controller which brought performance up significantly from the previous generation Gammix S10 SSD. These features along with the RAID Engine and Data Shaping help the drive’s integrity and endurance with the S11 480 GB sporting a 320 TBW and 5-year warranty to back it up. At this price point, there are multiple options which will do the job for the enthusiast, so be sure to look at reviews and the data as that is about the only way users can see a difference in such fast drives. Pricing is fair among its competition and performance is good for the price so the Gammix S11 receives an “Approved” award.
Click to find out what this means
Joe Shields – Earthdog
About Joe Shields 327 Articles
Joe started writing around 2010 for Overclockers.com covering the latest news and reviews that include video cards, motherboards, storage and processors. In 2018, he went ‘pro’ writing for Anandtech.com covering news and motherboards. Eventually, he landed at Tom’s Hardware where he wrote news, covered graphic card reviews, and currently writes motherboard reviews. If you can’t find him benchmarking and gathering data, Joe can be found working on his website (Overclockers.com), supporting his two kids in athletics, hanging out with his wife catching up on Game of Thrones, watching sports (Go Browns/Guardians/Cavs/Buckeyes!), or playing PUBG on PC.
Loading new replies...
Avatar of Alaric
Alaric
8,237 messages 7 likes
The 21st century was supposed to have us colonizing other planets, quantum computing for the masses, etc.. Instead we have "blower card" storage with RGB. :rofl:
Not saying either is a bad idea, but I had to say blower card storage with RGB once publicly. :D The usual great writing and review from ED, and what appears to be a decent product. I've been happy with my $40 Adata SSD. It seems like they are expanding in to the market steadily at the consumer level, and competition is always good.
Reply Like
Avatar of Culbrelai
Culbrelai
1,804 messages 9 likes
I always thought it was interesting how m.2 slots are now coming with heatsinks on motherboards.
Do nvme drives really get that hot?
Reply Like
Avatar of ATMINSIDE
ATMINSIDE
23,924 messages 428 likes
If they're getting beaten on the controller on the SSD can get quite warm.
Reply Like
Avatar of EarthDog
EarthDog
Gulper Nozzle Co-Owner
77,327 messages 3,987 likes
Avatar of freakdiablo
freakdiablo
5,573 messages 1,018 likes
They'll get warmer, yeah, to the point where the controllers on some will throttle slightly (IIRC). The location of the slot on many boards doesn't help, sandwiched between a graphics card and the chipset, both pumping out heat and causing airflow to stagnate around the drive.
Edit: Damn, didn't realize I didn't refresh the page lol
Reply Like
