Alphacool Announces White Edition Rise Aurora Series Fans
Alphacool Featured
Alphacool has just announced the white edition to the Rise Aurora series fans. Available in 120 mm or 140 mm and now black or white, the Rise Aurora boasts some pretty impressive specifications. The Rise Aurora fans are PWM controlled and feature ARGB lighting. Priced at $20.23 for the 120 mm and $23.43 for the 140 mm fans, the new white series is the perfect match for your all-white build. Below is Alphacool’s press release.
Alphacool White Rise Aurora Series Fans
Due to high customer demand, Alphacool is expanding its Special White Edition and now also offers the Rise Aurora fans in white. The fans perfectly match the white NexXxos radiators and the connectors of the Eizapfen White Edition in terms of color. The digital aRGBs create a unique illumination to complete the visual appearance.
Alphacool’s Rise Aurora doesn’t just score points for its design, though. Like the model in black, the fan is offered in 120mm or 140mm. Due to the high airflow (120mm 154.1 m³/h | 140mm 154.1 m³/h) paired with a high static pressure (120mm 3.17 mm/H₂O | 140mm 2.20 mm/H₂O), the fan is perfect for mounting on radiators of a water cooling system or for ventilating a case.
Other plus points are the wide PWM controllable control range (e.g. 0-2500 rpm for the 120mm variant) as well as the decouplers on the frame and the tear-off edges on the fan blades, which make the Rise Aurora the perfect choice for a silently operated case or water cooling system.
Technical data fanRise Aurora 120mmRise Aurora 140mm
L x W x H120 x 120 x 25mm140 x 140 x 25mm
RPM0-2500 rpm (+/-10%)0-2000 rpm (+/-10%)
BearingSleeve BearingSleeve Bearing
Connection4-Pin PWM4-Pin PWM
Voltage12V DC12V DC
Power consumption8,64 Watt (max)6,60 Watt (max)
Current consumption0,65A (0.72A max)0,50A (0.55A max)
Static pressure3,17 mm/H2O2,20 mm/H2O
Max. air flow118,9 m³/h154,1 m³/h
Noisemax. 31,5 dB(A)max. 38,4 dB(A)
MTBF30,000h30,000h
Speedometer signalyesyes
Auto-Restartyesyes
Technical data aRGB illumination
LED type5V aRGB5V aRGB
Connection3-Pin JST3-Pin JST
Max. current consumption LEDs3,5W3,5W
LED quantityFrame: 12 / Hub: 8Frame: 16 / Hub: 8
MSRP18,99 €21,99 €
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of Overclockers.com
3,224 messages 219 likes
Alphacool has just announced the white edition to the Rise Aurora series fans. Available in 120 mm or 140 mm and now black or white, the Rise Aurora boasts some pretty impressive specifications. The Rise Aurora fans are PWM controlled and feature ARGB lighting. Priced at $20.23 for the 120 mm and $23.43 for the 140 mm fans, the new white series is the perfect match for your all-white build. Below is Alphacool's press release.
Click here to read more!
Reply Like
