Azza REGIS 902
Table of Contents
Azza just announced the REGIS 902, a unique mid-size cube ATX chassis. The REGIS 902 is an original design that looks more like a piece of art rather than a computer cabinet. At the forefront of its features is the addressable RGB infinity mirror front panel. It’s not all looks though, with the ability to house 210 mm tall CPU coolers, two 240/280 mm liquid coolers, and up to 336 mm graphics cards, the REGIS 902 is capable of housing some powerful builds.
Pre-ordering is available through Newegg and will be available soon on Amazon. Unfortunately, this unique case is not a budget-friendly option and will set you back a hefty $399. For additional information please read Azza’s press release below.
AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB – REGIS 902
December 3rd, 2021, Taipei, Taiwan – AZZA, a leading brand of computer cases and accessories, introduces the REGIS 902. This luxury case is uniquely designed with a cube form factor, elevated above the surface by a premium aluminum stand, and has an infinity mirror addressable RGB front panel. The exterior is complemented with black tinted tempered glass panels and two brushed aluminum mesh panels with a touch of gold trim on the edges. ATX motherboard compatible, the REGIS supports up to 336mm long GPUs and dual 240/280 radiators.
Luxury designed case with unique cube form factor
Infinity mirror addressable RGB front panel
3-sided black tinted tempered glass panels with gold trims
CNC-milled 8mm aluminum stand to elevate the case
Supports up to 336mm max. GPU length and dual 240/280 radiators
Azza REGIS 902
Luxurious Cube Designed
The REGIS has 3-sided black tinted tempered glass panels, two sides for displaying the system, and the front for featuring an infinity mirror addressable RGB which uses an ultra-thin lighting module. The addressable RGB can be controlled via the case button, or synchronized with any motherboard software. At the bottom, two anodized and brushed aluminum panels with large mesh openings complete the frame of the Regis. Each panel is mounted on snap pins for tool-less removal. In addition, golden trims on 4 of the edges highlight the luxurious look of the cube.
A Stand that Elevates
Meticulously designed, the CNC milled 8mm thick aluminum stand secures the REGIS in place at 45 degrees and elevates the case 175mm off the surface (at the highest point). This unique positioning allows the REGIS to be showcased from all angles. It also gives the REGIS a reduced footprint and improves airflow with two mesh panels for air intake from the bottom of the case.
High-end PC Ready
Capable of supporting full mini-ITX, mATX, ATX motherboards, and ATX PSU, the REGIS has enough clearance for 210mm tall CPU coolers, 336mm long graphics card, and up to 2x 240/280 radiators which can be first mounted on removable brackets outside of the case for ease of assembly. The REGIS also holds up to 2x 2.5” SSDs or 1x 2.5” SSD and 1x 3.5” HDD which can be placed in trays and mounted in multiple positions. The REGIS includes a 140mm PWM fan pre-installed at the rear and a PWM/ARGB hub which connects up to 7 ARGB devices and powers 6 PWM fans.
Smoke Gray with Gold Trim (Exterior)
Black (Interior)
Max CPU Cooler Height
Up to 210mm
Max GPU Length
Up to 336mm (horizontal)
Up to 320 (Vertical)
Motherboard Compatibility
ATX, Micro ATX, Mini ITX
2.5” Drive Bays
Up to 2
3.5” Drive Bays
1
Expansion Slots
7 (Horizontal) + 3 (Vertical)
I/O Ports
Power Button
LED Button
HD Audio
USB 3.0 x2
USB-C x1
Case Dimension (H x W x D)
610mm x 481mm x 529mm
Weight
12.05 kg / 27.6 lbs
System Fan support
Right: 2x 120mm or 2x 140mm
Left: 2x 120mm or 2x 140mm
Rear: 1x 120mm or 1x 140mm
Included Fan
1x 140mm Black Fan
Water Cooling
Right: Support radiators up to 240/280mm
Left: Supports radiators up to 240/280mm
Power Supply support
Bottom mounted ATX power supply
Accessories
1x Case Stand
1x AZZA Hub
About AZZA
AZZA, a Linkworld Electronic brand, is a leading manufacturer and distributor of a full range of computer cases. The company specializes in producing, and marketing uniquely designed computer products. To learn more about AZZA, please visit https://azza.gg/. Connect with AZZA on: Facebook, Instagram, Twitter,and YouTube.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
The XPG group, a division of ADATA, is best known for its excellent solid state drives and memory modules. The XPG Invader represents the first PC chassis to come to the market for Xtreme Performance Group. As such, they opted to manufacture “a sleek and versatile mid-tower chassis that sports a tool-less design, high-airflow layout, and a front RGB downlight that can be personalized with the XPG Prime™ ARGB Combo Controller.”
Newegg has now started to list Fractal Design products, including the Define R3. Today, we have the pleasure to introduce the Define R3 to the U.S. consumers unaware of Fractal Design and their products.
I think that Lian-Li or some other brands had a similar idea some years ago ... and it wasn't selling at all.
Somehow, this stand is not convincing me. Maybe for the ITX version but not for the ATX.
These artsy pieces definitely aren't my flavor of choice. Even the weird gamer cases like the Thermaltake AH-360, while they look cool, just aren't for me.
Loading new replies...
AKA: JrMiyagi
Powder Junkie Moderator
Benching Team Leader
