CoolerMaster Introduces MasterCase SL600M – Sleek Mid-Tower
Table of Contents
CoolerMaster has announced a new chassis in the MasterCase lineup named SL600M. The SL600M is the first in the SL series of cases CM says is designed to “blur the lines between work and play”. The exterior is made out of anodized aluminum and forgoes any RGB features which help the case to have a more appropriate appearance in a home office or workplace. Inside, they say ‘demanded an alternative perspective on system layouts and cooling’ and has multiple options for internal layouts adding flexibility for the internal setup.
The mid-tower chassis comes in silver and black with the body made of steel (along with the right side panel), the front and top panels of aluminum and the left side panel made from tempered glass allowing owners to show off the build inside. The case supports Micro-ITX, Mini-ATX, ATX, and E-ATX boards (up to 12″ x 10.7″) and has a total of seven + two expansion slots supporting vertical graphics card installations. Storage wise the SL600M is able to support four 2.5″/3.5″ drives which should be enough for most users, especially in this day and age of M.2 based storage modules.
The I/O Panel consists of several USB ports including a USB 3.1 (10 Gbps) Type-C port, two USB 3.0 Type-A ports, and two USB 2.0 ports. The audio ports used here are two 3.5mm jacks, one for audio+mic, and the other a dedicated microphone jack. The power button and HDD LEDs are white – the only form of LED one will find on the case! In order to control the fans, there is a slider which is able to speed up or slow down the attached fans via PWM control.
CoolerMaster goes on to say the internal layout is changed as well with a vertical orientation along with two 200mm intake fans at the base are said to take advantage of the natural convection of heat with a more direct airflow path to the internal components funneling more air through the top mesh of the case. There are dust filters on the bottom intake locations. Additionally, the top panel is also able to be raised in order to help with increased airflow. Graphics cards are also mounted vertically with the PCI mounting windows able to be rotated 90 degrees allowing for two graphics cards to be mounted vertically together and allows for direct airflow to the GPU(s).
As far as support goes, the SL600M is able to support a CPU cooler up to 191mm tall, a 200mm power supply, and up to a 318mm (12.5″) graphics card. The radiator support is plentiful with room up top for up to a 3x120mm or 2x140mm radiator (with a maximum thickness clearance of 43mm). The bottom will support the same sizes with an increased maximum thickness of 72mm with the graphics card installed vertically.
CoolerMaster SL600M Specifications
Product NameMasterCase SL600M
Available ColorSilver, Black
MaterialsBody – Steel
Front/Top Panel – Aluminum
Left Side Panel – Tempered Glass
Right Side Panel – Steel
Dimensions544(L) x 242(W) x 573(H)
21.4″ x 9.5″ x 22.5″
Motherboard SupportMini-ITX, Micro-ATX, ATX, E-ATX (up to 12″ x 10.7″)
Expansion Slots7 + 2
Drive Bays5.25″ – 0
Combo 3.5″ / 2.5″ – 4
SSD – 4
I/O PanelPower/HDD LED Color – White
1x USB 3.1 (10 Gbps) Type-C
2x USB 3.0 Type-A
2x USB 2.0 Type-A
Audio – 1x 3.5 mm combo jack, 1x 3.5 mm mic only jack
Fan Control4-step slide, 4-pin PWM (x4)
Preinstalled Fan(s)Top/Front/Rear – NA
Bottom – 2x 200 mm PWM (400-800RPM)
Radiator SupportTop – 120 mm, 140 mm, 240 mm, 280 mm, 360 mm (43 mm max thickness)
Bottom – 120 mm, 140 mm, 240 mm, 280 mm, 360 mm (72 mm max thickness w/GFX installed)
ClearancesCPU Cooler – 191 mm
Power Supply – 200 mm
GPU – 318 mm
Dust FiltersBottom
PSU SupportFront Top Mount, ATX
Price$199.99 (Newegg)
There wasn’t a mention of a specific date for availability in the PR, but it is up for presale on Newegg.com for $199.99 and should be available soon!
Joe Shields (Earthdog)
Related Articles:
About Joe Shields 341 Articles
Joe started writing around 2010 for Overclockers.com covering the latest news and reviews that include video cards, motherboards, storage and processors. In 2018, he went ‘pro’ writing for Anandtech.com covering news and motherboards. Eventually, he landed at Tom’s Hardware where he wrote news, covered graphic card reviews, and currently writes motherboard reviews. If you can’t find him benchmarking and gathering data, Joe can be found working on his website (Overclockers.com), supporting his two kids in athletics, hanging out with his wife catching up on Game of Thrones, watching sports (Go Browns/Guardians/Cavs/Buckeyes!), or playing PUBG on PC.
Loading new replies...
Avatar of Alaric
Alaric
8,237 messages 7 likes
Nice write up! Am I the only one who sees $200 for a mid tower as kind of high? Or am I just that out of touch?
Reply Like
Avatar of Shuruga2
Shuruga2
671 messages 4 likes
This case was on my shopping list, until I changed to an EATX board that wont fit. I was actually kind of excited for it, I like the look of that case
If some more boards come out supporting thunderbolt...
The plan was to fit 4x noctua 200mm fans in down draft including reversing the PSU fan. Hover Mode :)
Reply Like
Avatar of habbajabba
habbajabba
1,904 messages 1 likes
Xwing case trooper.
Reply Like
Avatar of Blaylock
Blaylock
8,052 messages 975 likes
EATX will fit this case, however, there will be some cable management sacrifices which you will find is typical for any mid-tower case with EATX support. Here's a link to my review of this case. If you have any questions or need further measurements just let me know. It's a very nice case and easy to work with.
Reply Like
