YEah, I'm running in Dual Channel right now. 4GB is enough, but definitely don't like the fact that the Mobo is not running the way it should.
No amount of tinkering can get my 6GB back. Time for RMA.
Sorry haven't posted in a while, been busy helping a friend drop his mercedes diesel in his toyota pickup... Talk about a headache!
Anyways, booted up my gaming rig after like 2 weeks of having not turned it on, and lo and behold, it only showed 4gb again.
So I opened the case, jiggled the c1 stick around, booted back into windows, and it still showed 4gb.
I then removed the c1 stick, looked into bios, and it then showed only 2gb of ram, so I think to myself, it has to be either a bad stick or socket at a1 or b1.
I took out b1, booted into bios and it showed 2gb, so I figure a1 is good, and b1 is my culprit. So I slap the stick back into b1, and boot up again, and it shows 4gb. I then start getting angry because the dog gone problem is still eluding me. So I finally put in the last stick into c1, and it shows up as the proper 6gb, and so I sit here now typing this, with everything "working properly" for now.
I figure it has to be an intermittent issue with the b1 socket. I'll have to run memtest with sticks in b1 socket and see what it shows me. Though I doubt that I'll see anything because the problem seems to go away for a while once you reseat the ram.
And the part that really blows is that just when I decided I'd go ahead and RMA it to newegg, I checked, and now it's been like 35 days since I ordered all these parts, so I guess I'm screwed blued and tattooed huh?
I don't know if this will help you guys, but my problem turned out to be dead simple. All I needed to do was upgrade my BIOS to 0901 from 0504. Changes that would kick me back down to 4gig now work as they should, with no change to reported RAM.
Yeah, I could always try that. I spent all of last night clearing BIOS, changing clocks, and changing DIMM placement etc. Nothing worked. I'll give it a go with another BIOS.
And also, instead of starting a new thread, figured I'd just ask here, but anyways, are these temp ranges in the normal when running prime95 torture test on 8 threads with round-off checking, with no overclocking using a stock intel heatsink (and 5x120mm case fans)...?
At 2.8 GHz, I would say possible? Yes. Realistic if you setup your board to generic specs? Hell no! I have a strange feeling your board is defaulting to high stock vcore.
Word of advice, I would go into the bios and manually select the option for vcore. Turn your vcore from auto to manual and set it at 1.08v. This will substantially lower your CPU and undervolt it a bit under VID usually. Your temps should drop to around 55 to 65 under load instead of the disturbing 85C. Something else to keep your temps even cooler at low vcore and low cpu speed is disabling HT (Hyperthreading). To do this, go into the bios by pressing DEL when you boot the computer and select the setting for CPU OPTIONS. Disable the setting for Intel HT Technology. On your next boot, this will 99% of the time give you on average a decrease of 10*C per core and increase your theoretical overclock by 100 to 200 mhz. The second option is only for people that dont need HT. The only real reason you would need HT on a Core i7-920 is if you have specifically tuned and HT optimized software. In many instances, games and applications will have a greater benefit with HT disabled because of added latency generated from the phsyical core instructions when a piece of software is not HT optimized. I honestly love overclocking with a passion! But I love people that choose to undervolt also so this is a great chance to experiment with how low she will go. lol
Since you are choosing to run at such an extremely low CPU speed of 2.8 GHz and you are on the stock Intel HSF, this is an excellent opportunity for you to get into undervolting and/or finding the lowest stable vcore to run at that low frequency.
So, by starting with 1.08 vcore and disabling HT I can guarantee your temps will drop around 20*C right off the bat from both idle and load and the PC will run better than ever assuming your stock vcore selection is much higher than VID at default. Remember, this undervolting and HT disabling trick is only a temporary fix until you get yourself a Venomous X Heatsink with dual push/pull panaflo's. At that time I expect you to be at 4.1+ Ghz all day long. I can help you out either way dude. One word of advice, as long as you are running the Intel stock HSF do not OC with anywhere near those temps.
New here - but was having exactly the same issues you were on a very similar build. I was pulling my hair out trying to figure out how to lower both the TEMP and figure out why windows was not recognizing all of my mem....ran all the tests, did all the reslotting, bios updates, etc.
First off - the memory...I was going INSANE trying to figure out my own problem with it. Alot of people suggest on boards across the internet that it may be a Mobo, slot, or mem issue. If you've checked every stick and they are all seated properly, then I do have a suggestion...reseat your CPU processor. Make sure that there is good contact between the CPU and the pins. I actually had a SMIDGE of thermal grease on a pin on the bottom of my CPU and it was causing the issues in reading the mem. I cleaned it with a bit of Arcticlean on a coffee filter, reseated it (making sure the CPU was perfectly in place) rebooted and on startup Windows recognized all 8 GB.
Now your Temps - I did so much research on it my eyes almost exploded. My temps would sit at 34c but then as soon as P95 started torch up to the 80's and I couldn't for the life of me figure out why. I eventually broke down and spent the $30 to junk the Intel Stock and go with the Cooler Master Hyper 212. No mods to the voltage or anything and the highest my CPU gets on full load (non OC'ed) is 45c after 8 thread FFT's test. Honestly, I totally agree with the post mentioning to lower your voltages, but why get a porche and treat it like a hyundia - the CM Hyper 212+ has made me forget all together about my temps and even opens the door for possible overclocking in the future. If you have the room in your case (fairly large) and don't mind taking out the Mobo one time (hey it gives you a chance to remanage your cables, etc) then I'd strongly consider.
I agree with you as well. I was more stating that since he does not want to OC and he is at such a low clockspeed of 2.8 Ghz, he is throwing way too much juice into it. Not to mention, if he plans on staying that close to stock core speed he might as well undervolt and disable HT since he is on the stock cooler. If he was on high end air cooling like yourself, I would tell him to go 200 X 20, 1.30v, and reboot the rig at 4.0 Ghz all day long bc he would be essentially wasting a ton of available oc clockspeed. The i7-920 is golden, and one of the easiest if not the best 4.0 GHz capable quad cores on the market.
Jeeze, sorry my posts are so few and far in between. Been crazy busy lately, and no time for my hobbies lol.
Anyhow, thanks a TON for the help Dom. Thanks for the input too nfried.
But anyways, I just turned the rig on after letting it sit since thursday night just now, and surprise, surprise, it only showed 4gb (and that's AFTER having updated to that newest bios, 0805). So it's STILL having issues. On a whim, I went ahead and reseated the middle (b1) stick. That seemed to do the trick, and all 6gigs showed up.
And I went ahead and took your advice on changing the vcore and turning off HT. BOY HOWDY, WHAT A DIFFERENCE! Though on my little sidebar, it now only shows 4cores, which is ok since I assume HT just makes an addition 4 "virtual" cores. While running prime95 on 4cores, Core Temp shows my low idle @ 39-44c, and my load high temp for 15mins has been at a peak of 58c!
So that solved my high temp issues splendidly! So now, I'm really just concerned about the whole original ram issue (for now. I'm sure other issues will pop into my head lol)... Any other thoughts on that front?
Wow look at those temp differences. just as I predicted. I am glad that I got your loaded CPU temps down to 58*C from 84*C! LOL Believe me, I have owned so many 920 C0's and D0's I couldve probably worked as an Intel Distributor.. I know the ins and outs of these buggers like mark mcguire knows steroids.
In any event. Now remember unless you need to undervolt for a word processing or office rig (strictly office type apps, multimedia, no gaming, no encoding, no heavy processing) this is only a temporary fix. As I stated previously, you need to remember you are running a golden Core i7-920 D0 processor, this is one of, if not the best 4.0 GHz oc quad core ever to exist. So, I recommend you buying a Venomous X high end CPU cooler with 2 fans in a push pull configuration. After setting up your new air cooling setup you should go back to selecting 1.30vcore and go 200 X 20 for 4.0 GHz 24/7 as a daily overclock.
I am a big fan of disabling Hyperthreading. Deathman, myself, evilsizer and many other old school contributing members on this forum have tested on/off HT for many games and apps. Most games will lose about 5% to 7% of FPS due to added latency from 4 extra threads not to mention as we have proven in this very thread, you will gain about 100 to 200 mhz on your overclock + lower temps by 10*C each core on average because of less strain on each core. Many newer games and apps are Multicore optimized for physical cores, but I would have to say there is less than a 5 percentile otpimized for multicore + Hyperthreading. So, to answer your question yes your amount of cores in windows task manager will go from 8 to 4, but those extra 4 cores/threads are for the most part adding latency and slowing down total processing time UNLESS the game/app is HT optimized. You will be very hard pressed to find any game currently on the market that is HT optimized.
I'm experiencing a similar problem as well with X58UD5 and Mushkin Redlines. Everything in windows shows 6GB, but when I do each slot in CPU-Z only slots 1 and 3 show up. Also, in memtest only two of the sticks show their SPDs but it shows 6GB. Any thoughts?
Alright, sorry for the long in-between-er again lol. I went shopping once I finally hit upon what I thought might be my issue with the ram. I noticed that one of my exhaust fans on the top of my case was actually barely touching the locks for the ram dimms, and I figured that maybe the vibrations of the fan were slowly making the dimms back out. So I took out that fan, ran it for a day or two, and so far, I haven't had any issues with the ram not showing up (keeping my fingers crossed).
So anyways, I went shopping today. I managed to score a brand new dell 22" full 1080p, 1920x1080, 5ms with HDMI monitor from best buy for $139.99 today. Probably one of the best scores I've every made at BB. They had it miss labeled, so I had the gf throw a god almighty horrendous screeching b**** fit, and they graciously honored the wrong card in front of the monitor.
I also happened to glance in their other aisle and I saw a single lonely Corsair H50 sitting there screaming my name with a sweet price tag of $59.99 (it's currently $79.99 @ newegg. Was going to order it today, but got a wild hair up my *** to go to BB), so I picked up that as well.
So I've spent the last few hours installing this new h50 and SQUEEZING (barely, had to use some zip ties in places) all 6 case fans into this TINY "mid tower" ThermalTake case lol. And it all looks killer with my wire routing "skills"/ocd. I'll have to take some pictures whenever I get the motivation to do so...
Anyhow, I turned back on HT, and put the juice back up to auto just to take a gander and see how well she preforms and cools now. Needless to say, with prime95 doing a 8-threaded torture blend test, I am pleasantly impressed with it's cooling over that horrible stock intel hs/f.
Picture:
Note: Yeah I really dunno what to do with all this new found screen realestate! It's awesome!
And, I guess now's about time I start screwing with actually overclocking this rig eh?
Sweet baby badonk adonk! 4ghz with this h50! Awesome! Turned off HT again, turned vcore up to 1.3, 200x20 just like you told me Dom! And over 15mins on prime95, and it's still stable @~65ºc!
Now I've gotta figure out how to play with the ram speeds... But it's time for bed. If I don't drag my self away right now, I'm not gonna be going to work tomorrow... Lol
And finally (yeah I know, I lied about going to bed... I will right after this lol)
4.2ghz @ 1.3v/vcore, 800mhz @ 1.5v/dram. Have no idea if that's a decent OC or not (failed to boot with mem at 1000mhz using that xmp deal), but I do remember not to move the dram and vcore more than 0.5v away from each other. But setting my ram from 600mhz to 800mhz and still being on the same 1.5v sounds OK to me (but then again, what do I know?)
Hoping someone will look at what I posted and give me a little guidance, whether good job, or constructive criticism. Gonna leave prime95 burning all night and check it in the morning.
1.3v on the QPI/DRAM should be more than sufficient to run that bclock with 6GB of ram at 800MHz. You could probably drop it even more TBH, but that;s where I leave mine for 24/7 stability.
Really the only thing that you're pushing hard is your chip with that high multi, so other than making sure your Vcore is in line, the rest should be fine as is. vDIMM at 1.5v regardless of the manufacturer's specs is something that might need to be bumped up at some point for greater stability. Just keep an eye on it.
A 1.3v 4.2GHz with that processor is quite an achievement if you can keep it stable. Personally I'd just back it off to 4GHz and get the vcore lower, but that's because I run HT for Folding.
Have you ever reseated your cpu? A lot of times the "4gb instead of 6gb" is because the cpu is not seated properly on the pins. VRef can also play a part in this too as some have come to find out.
