- Apr 6, 2005
Hi, first post
I had the first mobo that supported DDR - Iwill KA 266 and that pos started goin crazy where the bios would clear itself or the system would just reboot for no reason. I went and bought an AS7333 from a store for like 60 bux cause I had no money or time (needed mobo for school).
I read the back quickly and it said overclocker friendly and being an Asus I trusted it, but of course the mobo sucks for oc'ing.
Anywho, you can't do any voltage changes at all.
Processor #1
Processor Information:
CPU Vendor: AuthenticAMD Platform: Socket A (Socket 462)
Processor: AMD AthlonXP (Thoroughbred 'B') Version: 1.14
CPU Type: Original OEM processor
Name String: AMD Athlon(TM) XP 2600+
Instructions: MMX (Ext), 3DNow (Ext), SSE
CPUID Information:
Standard: Family: 6 Model: 8 Stepping: 1
Extened: Ext. Family: 7 Ext. Model: 8 Brand ID: N/A
Process: 130nm
Revision: B0
CPU & Bus Speed:
CPU Speed: 2205.00MHz
CPU Multiplier: x 15.0
CPU FSB Speed: 147.00MHz
Bus Speed: 294.00 (DDR)
Basic Cache Information:
L1 Instr. Cache size: 64KBytes
L1 Data Cache size: 64KBytes
L2 Cache size: 256KBytes
At 148 fsb windows xp screen will show and that nightrider thing will freeze.
I have 256MB of crucial and 512mb of something with the same latencies both PC266. When I lower the multiplier or up it and lower the fsb (to keep it at stock) it wont boot meaning my cpu is locked right?
So I need to unlock my cpu and/or mod it to get higher default voltage so I can run higher speeds without skippage.
http://www.ocinside.de/go_e.html?/html/workshop/pinmod/amd_pinmod.html
That site says you can do it by wrapping copper wire around the pins under your cpu I guess. I'm wondering if you can actually do that without frying something and if anything else I need to do.
I'de appreciate any help.
P.S
I have no lil fan on my SIS 745 but I have 2 rear 80mm fans, one side, and 4 front. My cpu has that turnbine fan thingy with the magnets around the fan for more airflow running at 5000 rpm. Idle I get 44C I think.
Processor #1
CPUID Information:
Process: 130nm
Revision: B0
CPU & Bus Speed:
P.S
