- Aug 29, 2007
Water & Wood
This is a desk build...in other words, it will be built into my desk. The desk is made from pine, which is why I'm calling this Water & Wood.
Direct links to updates:
- motherboard tray slider installation
- GPU waterblocks and the fan wall
- more pics of the fan wall assembled
- first reassembly
- fill port and leak testing
- final loop flush
- PWM controller wired, and blocks cleaned & mounted
- first fulll assembly with water cooling
- initial temp testing, air VS water
- 1st dust filter built, and pump mounted
- work started on the front panel, and PSU sleeving complete
- work started on the front door and window
- work on the front door continues...until disaster strikes...also new air filter installed
- new GPU backplates installed ...then tragedy strikes the 2nd front door
- Impressive the difference proper tools can make
- Water & Wood is nominated for bit-tech's MOTM...VOTE FOR ME!
Direct links to videos:
- water cooling components 1st flush
- custom PWM fan wall in operation
- loop flow demo
- 1700W from a 1050W PSU!!!
- window etching time lapse video
- Playing a little DCS A-10C with headtracking
Parts list
- Asus Maximus IV Extreme
- Intel i7 2600K
- 2x4GB G.SKILL DDR3-1866 9-10-9-28
- 3x reference GTX 580s
- 120GB OCZ Vertex 3
- 500GB Momentus XT 2.5" HDD
- 1050W Enermax Revolution
Water cooling parts
- Swiftech Apogee XT (Rev 2) CPU block
- 3x EK Full cover acetal & nickel GPU blocks
- 3x Swiftech MCR420-QP radiator with Koolance CNT-RP402X2 bridges (meant for a Koolance res not used here).
- Swiftech MCP35X pumps with 35X res
- 12x Adda 98.6 CFM fans (with custom 0-100% PWM control, thanks xXSebasXx & Bobnova )
- 3/8 ID, 5/8 OD black Primochill tubing
- Enzotech compression fittings
- Koolance quick disconnects
I've got quite a few unique ideas for this build, but it's going to be slow going for another month or so. I'm still working out a full parts list, but many are asking about the build, so I wanted to give you something to look at while you wait
Swiftech and Coldzero Team will be sponsoring this build, thanks a ton!
Read my Maximus IV Extreme review here: part 1, part 2
I plugged the loop into Martin's Pump & Rad Optimizer to see what it said...of course there are a couple caveats
- My rads are 420s, not 320s
- My blocks are the new (more restrictive) design for the 580
- My CPU is planned to be run in parallel with the GPUs
idle (200W -- 1000RPM -- pump @ 50%)
max load (1000W -- 2600RPM -- pump @ 100%)
