- Jul 11, 2001
- Southern California
Hi all, i am building a new server for my office, and i am ordering all the parts tonight! Just wanted to see what everyone thinks of the components and if there is ANYHTING they think is better, or that i should change for any reason? Thanks in advance! here is the list:
*edit* One thing i am not sure of is if i need a redundant power supply? Is one really needed, or will the antec i have do for the 2 Xeons? Thanks again!
Mobo-SuperMicro P4DP6 Dual processor Motherboard for Intel Xeon Retail
Specifications: Processor Support Dual Intel® Xeon™ processors up to 2.40GHz and faster with 512K L2 cache.Chipset Intel E7500 chipset
Front Side Bus 400 MHz. Up to 16 GB ECC registered DDR-200 memory in 8 DIMM slots. I/O Expansion Total: 6 PCI-X slots Max up to 2 64-bit 133MHz PCI-X. Default setting: 2 64-bit 100MHz PCI-X. 4 64-bit 66MHz PCI.1 VXB (Virtual Extended Bus). Ports: 2xIntel 82550 fast Ethernet ATI Rage XL 8MB PCI graphic controller.
CPU's- (2) Intel Pentium 4 Xeon 2.2GHz 400MHz BUS, 512KB L2 Cache Mftr Part#: BX80532KC2200D Retail Boxed
Specifications:
CPU: 2.2 GHz
Type: Pentium 4 XEON
Cache: 512K
BUS: 400 MHZ
Socket: 603 Pin (FC-BGA) Retail (Box with Heatsink and fan)
HD's- (2) *in a raid 1* FUJITSU SCSI HARD DRIVE 36GB 15,000RPM MODEL # MAM3367MP - OEM, DRIVE ONLY
Specifications:
Size: 36.7 Gigabytes
Interface: SCSI Ultra2 Wide 68 Pin Ultra160/320
Seek time: 3.5ms
Transfer Rate: 160MB/Sec
RPM:15,000
Cache: 8MB
OEM(Drive alone) 5 Year Manufacturer Warranty
Raid controller- Adaptec SCSI Raid 2000S
48 Mbyte onboard ECC SDRAM
64-bit/66MHz PCI
Adaptec AIC™-7930W microprocessor with hardware XOR
ECC RAM- (4) 512mb sticks of Crucial DDR PC2100 • CL=2.5 • Registered • ECC • 7.5ns • 2.5V • 64Meg x 72
Floppy- SONY 1.44MB 3.5 INCH INTERNAL FDD DRIVE
CD-rom- SONY 52X MAX EIDE INTERNAL CD-ROM DRIVE
Case- Lian-Li PC-76(20-Bay) Aluminum ATX SERVER case. 6 - 5.25" bays, 2 - 3.5" bays, 12 - 3.5" hidden bays, Pentium 4 compatible. Color: SILVER(HARD ANODIZED). 6 cooling fan(4 x 80mm, 2 x 120mm). Size: 265x559x630mm. Available for DUAL CPU M/B. Model #: PC-76, No Power Supply. Power Supply Sold Separately. Model#: PC-76
PSU- Antec 550W Power Supply For TRUE550 ATX Form Factor, ATX12V compliant for Pentium 4 (backward compatible with previous Pentium versions) and AMD systems
+5V Stand-By & Logic On/Off Antec Low Noise Technology Maximum Power 550W Weight 5 lbs. Dimensions - L5.9" x W5.5" x H3.4" UL, CSA, TUV, CB, CE, NEMKO Approved Model#: TRUE550
Specifications:
CPU: 2.2 GHz
Cache: 512K
BUS: 400 MHZ
Specifications:
Seek time: 3.5ms
RPM:15,000
Cache: 8MB
64-bit/66MHz PCI
