- Feb 12, 2005
- Michigan
Have you tried loading BIOS P06 on there? I heard it's the best one out so far.
Thanks chawks2.nice maxx ^^^^
Foxconn "BloodRAGE" Bios P06 Settings
Havent seen many posts with BIOS settings, so figure I offer my own.
In my experience, the items in red text are the most important for a successful i7 oc.
QUANTUM BIOS
BCLK(FSB) - [210]
CPU Turbo - [Disabled]
SYS Turbo - [Enabled]
QPI Link Fast Mode - [Enabled]
QPI Multi - [Auto]
CPU Core Multi - [x20]
CPU Uncore - [x12] <= {stability = MBM x 2 = CPU Uncore}
Memory Bus Multi - [x6]
CPU Clock Skew - [0ps]
IOH Clock Skew - [0ps]
-CPU FEATURES
-Memory Settings
-PPM - [Enabled]
-EIST - [Disabled]
-CxE - [Disabled]
-EDB - [Disabled]
-Virtualization - [Disabled]
-HT - [Enabled]
-APC - [ALL]
VOLTAGE SETTINGS
-IMC - [Enabled]
-Channel Config - [Independent]
-Channel Interleave- [6 way]
-Rank Interleave- [4 way]
-Virtual XMP - [Disabled]
-DRAM - [Manual]
-tCL - [9]
-tRCD - [9]
-tRP - [9]
-tRAS - [24]
-CR-[Auto]
-tRFC - [88T]
-tWR-[Auto]
-tWTR -[15T]
-tRRD[6T]
-tRTP[6T]
-CPU Core - [+260mv]
-CPU Vdroop - [Disabled]
-CPU VTT - [+60mv]
-1.8 PLL - [1.8]
-DRAM - [1.65]
1. did you update your BIOS? is it suggested once you get the board running?
2. what are your idle and load temps with that OC?
3. what is your stock ram timing?
I have not updated the BIOS past P06, YET.
Temps for that C0 batch 920 were decent. Ambient temperature plays a huge factor in my setup, the summer in NY has been cool so far. Idle=50 Load=70, on air!
Stock RAM timing was 9-9-9-24. However, my OCZ Gold stix needed an exact configuration, I can post this later.
I have been experimenting with my D0 + Redlines, I will be updating this thread before the end of the month with some results. Stay tuned!
i have OCZ Gold sticks, it would be nice if you could take a screen shot of how you manually configured them with your CPU OC.
