- Apr 24, 2005
I'll be getting mine tomorrow, if not, then on monday. Will post then
bri1 said:ya seems a little week concidering its a 148 but you should get more with a good board either way i havent seen many results on 148s maby they dont oc as well
No, higher multiplier only means that the person will need lower HTT speed to hit a certain CPU speed, other than that it all depends on luck of the draw.bri1 said:you sure i mean 148 starts with a 11 multiplyer as apposed to a 9 multiplyer so with each mhz added to fsb its 11 mhz to cpu so wouldent that make it ezier to get higher clocks?
Post a pic of the pin you broke off, with enough luck it'd be a "NC" (Not Connected) pin and the CPU will still work. Someone on XS managed to break off like 15 or something pins and his CPU still worked great.ocZer said:BOOHOOO!!1 I was just going to fit my brand new opteron 148 CABYE 0540 FPBW , when i noticed one of the pins where bent, all the way. Tried bend it back just in case but it instantly broke off. Didn't get the chance to even test it. Now I got to RMA, and I might not even get a good one. I'm so sad
cuda70383 said:got mine @ monarch
see sig
