- Sep 7, 2013
setx GPU_MAX_ALL_OC_PERCENT 100
setx GPU_USE_SYNC_OBJECTS 1
del *.bin
ultracoinminer -o stratum+tcp://ultra.nitro.org:3337 -u Blaylock.1 -p 1 --scrypt-jane --sj-nfmin 4 --sj-nfmax 30 --sj-time 1388361600 -w 256 -s 1 -E 10 -I 19 -g 1 --thread-concurrency 8192 --auto-fan --queue 0 --temp-target 70 --temp-overheat 80 --gpu-fan 75-95
Would someone consider downloading the UTC windows miner zip file and uploading it here? I can't get either download link to work.
"device" : "1,2",
"api-listen" : true,
"intensity" : "18",
"vectors" : "1",
"worksize" : "512",
"kernel" : "scrypt-jane",
"failover-only" : true,
"temp-cutoff" : "95",
"temp-overheat" : "80",
"temp-target" : "75",
"expiry" : "30",
"log" : "5",
"queue" : "1",
"retry-pause" : "5",
"scan-time" : "60",
"scrypt-jane" : true,
"sj-nfmin" : "4",
"sj-nfmax" : "30",
"sj-time" : "1388361600",
"temp-hysteresis" : "3",
"shaders" : "2816",
"thread-concurrency" : "32765",
"gpu-powertune" : "20",
"gpu-thread" : "1",
"sharethreads" : "32",
"lookup-gap" : "2",
"gpu-engine" : "940",
"gpu-memclock" : "1400"
Have either of you tried I 13? I lose hash rates when my intensity is too high for the system. Nothing to do with TC/ram, it just hates over I 13.
'bout to pop my 240 over to UTC. Just about done tuning YACoin.
