- Sep 15, 2007
- Small town Emlenton, PA
Scheme is up to you.
The lovely people at FrozenCPU have the 480mm Monsta on Orderable and I'm happy now. Thing is now, I'm being extremely indecisive on my color scheme here. I have to decide for a color for my XSPC Photon LED, the CPU block and my tubing. Not entirely sure here, what to go on black, any ideas? I'm sorry I've annoyed you guys with over 8 pages of indecisiveness and inexperience
Well, I'll be having multi colored LEDs and the ones I'll be getting do ~16 colors but no UV. Considering the multi LEDs, I am leaning towards White/Red. My decision is slowly narrowing down. Hopefully in time when the XSPC D5 Photon comes inJust go for something that stands out to YOU. Example of UV Blue tubing from XSPC in my own setup attached, by day it just looks a dark blue, but in the dark, it glows with that single uv light and brings it to life. The UV lights I ended up ordering came from Akasa(Since you can't find AC Ryan anymore, selection of quality UV cathodes is limited), so I had to import them from the UK, but they have been running flawlessly.
Only thing I don't like about those Photons is the fact that they stuck their XSPC logo on the clear tubing so when it lights up you will be seeing that. Kind of like the writing on some tubing. Most tubing have taken the labels off. Kind of annoying but still a nice looking cylinder reservoir.
Actually it's a solid acrylic rod that is "frosted". You can orient it to where the logo is facing away from field of view. The logo is not too large so really is a non issue.
Boy, don't I feel stupid. Yeah I didn't know I could bend the silver coil. For my loop would you say 2 is safe enough? My loop isn't that big but it isn't that small.Put it down a tube that has flow to the barb/compression so if it moves it will stop at the smaller ID of the fitting. Trust me, it won't move. Guess you don't know you can form them to any shape. I make them a bit bigger than the tubing and slide it in and use a dealybop to move it in an inch or so. Once it's in your hands you'll see. Look at the rebuild thread of my build in my sticky thread. There is a pic up top of two killcoils.
It won't move. Trust your instincts. After almost 180 posts, I hope you'll do fine...
Even with 3.1mmH2O 63 CFM @ 2350 RPM performing better than gentle typhoons at the cost of higher noise/rpm? Are you sure you're not confusing it for its 1.29mmH2O 38 CFM @ 1450 RPM Quiet counterpart?it might have be said before... you know that for that monsta you'll have to go push/pull with those SP120's ?
