The thermal clips are a huge step backwards technology wise. The more advanced guns in the first game wouldn't overheat at all unless you were trying. Not only that but the biotic and tech powers have a universal cooldown in me2, it's very annoying. It is nice being able to aim, but the ammo supply is too smal for shotguns and sniper rifles. I was a vanguard and rarely used my shotgun. I'm glad I was able to learn to use assault rifles because they are the best weapons again.
If I recall, when you get the ammo capacity upgrades for shotguns you carry 40 rounds instead of 15.
I got stuck in this game SO MANY TIMES. I had to reload quite a few times because of this.
Most of the time, It would happen when I would cover against a wall, and I'd move over to I can get closer to the door way, and It would sometimes cause me to walk UP the wall. Could never get back down. Had to reload.
Also had this happen when I was on a planet where a ship fell and crashed on the ledge of a cliff, and you have to walk along the beams to get to the computer in the back. I was literally on the last beam, headed to the terminal, when it happened. I was stuck walking ABOVE the beams and platforms, and could only walk in spots where there was nothing under my feet. I was literally only 20 feet away from the damn terminal.
But other than the walking through / over / between walls in the game, I didn't notice any other bugs. But that's me. Some people had other bugs.
One problem people are / were having is REALLY REALLY long loading times. They found out this was a multi-core processor problem. So if you are having VERY long load times, once your in the game, Minimize it ( ALT+TAB ) then go into your task manager ( CTRL+ALT+DEL, or right click your taskbar and go to the task manager ). Then go to processes. Find MassEffect2.exe. Right click it, then click "Set Affinity". Uncheck your 2nd processor core. Hit "OK". Then Right click MassEffect.exe in the task manager again, and do the same thing, but this time, turn the 2nd core back on, and hit ok.
Bring the game back up, and see if the load times are better.
Also, I've been messing around with the .ini files, changing some stuff in the game. I've made the game look MUCH better ( in my opinion. ) Turning off Depth Of Field really helps you see a lot detail in the textures. With it on ( which it is by default ), it makes everything much darker than it should be ( changing your gamma settings won't fix it. )
I also greatly increased the resolution of the shadows. God, the shadows look MUCH better now. Tried increasing the resolution of some of the textures. I think it helped a bit...But it's hard to notice. Also turned off VSync ( it's on be default ). That increased my average Frame Rate by 12 FPS. ( even after I did the shadow enhancement, and other tweaks. ) But with VSync off, you can't use Film Grain or Motion blur. Evidently those need Vsync. But I don't use them anyways.
Zex, care to give some pointers on how you changed these settings?
Motion blur seems to be on even though I've forced off Vsync. Film grain I can't tell.
Well, now you're just being finicky for the sake of your opinion.
Well, after 27 hours I've finally beaten it.
I tried to make decisions realstically. To be honest, I wanted to take more time at it, but I sort of got forced into going after the collectors seeing as how they abducted my crew. Thankfully I got everyone out, seemingly. I lost two people along the way though. *sigh*
Thane and Legion. Thane was a big meh, very boring. Legion on the other hand, he was awesome.
:O! You let thane die??? WHYYY? He was awesome! Couldn't you have let grunt die instead?
There is a way to save everyone (since you get an achivement for it) but I can't seem to figure out what combination of people you use. I know you use jack as the biotic to protect you from the swams but after that I'm not sure
Hopefully someone can help me
Does that mean you can also save Kelly + other crew? It's worth loosing a few people for them
Also I don't have Miranda and Samara's loyalty (I took jacks side and don't have time for Samaras mission before leaving.) Will this make a difference?
