- Aug 3, 2010
Well I just moved and destroyed one of my fans on my hs... I broke the the shaft off the fan and I am now in the market for new fans and I want to stick with quiet and cheap fans... Which one to choose or suggest something better.. My limit is around $10 buck a piece and I am not sure but I might be getting the the new nzxt tempest 210 ...My spec are down below
Fan needed-
4 x 120mm - 1 fan for front of case , 2 for push n pull setup on hs , 1 just extra in case of one breaking
1x 140mm or 120 mm for top mount on case but not sure to go with 140mm or 120mm
Idea for the fans
Yate Loon 140mm D14SM-12 Medium Speed Case Fan 62CFM 29dBA
Yate Loon 120mm D12SH-12 High Speed Case Fan 88CFM 40dBA
Yate Loon 120mm UV Blue D12SH-124UB High Speed Case Fan 80CFM 40dBA
Cooler Master R4-L2R-20AR-R1 120mm Red LED Silent Case Fan 90CFM 19dBA
XIGMATEK XLF-F1253 120mm 4 white LED Orange Case Fan PSU Molex Adapter/extender included
Fan needed-
Idea for the fans
