- Apr 20, 2004
- JAX, Mississauna
Well I had my answer to "should I go higher" all typed up and before I got ready to post it...you guys settled the deal. Hehehe. Congrats. Good job. Nice pics.
RGone...
RGone...
Does that tell us piledriver likes multiplier > HTT method of overclcking? Or atleast for cinebench?
+1 If you are really planning on going full custom water, READ and then Re-Read. When your done read it again, then get a budget in mind and pick out the parts.Tips on watercooling are read the stickies in the top of the WC forum. You will have a much better idea what your getting yourself into once you check them out. Also look through some build logs, especially ones with the same case as you.
Sleeving is fairly simple, you need a high temp air gun(some blowdryers will work) sleeving in your choice of color and size, and finally some heatshrink. They make modders tools for taking apart each of the different connectors, but you can pretty much do without them if your handy.
