- Oct 23, 2004
Alright, I've been lurking these forums for a while now, and after I finally got an email address that the forums will take, I am going to announce the project I'm gonna be working on for my first mod job. I decided not to take on major problems here, but just make my case look better than it is. (The whole pre-mod look lost its appeal rather quickly.)
Pretty much my ideas are as follows:
-Door panel gets a window
-Slight window mod, to make it easier to see through, and replacing window acrylic. (At 2.30 USD for a sheet the size of my window, I really can't go wrong here)
-Add a top blowhole, and maybe a window
-Full paint job, pure white+clear coat.
-Gelpenning motherboard
-Replacing a slot for two 80mm fans with one 92mm opening
-Replacing fans
-Real wire management to replace the ultimate ghettoness. (Electrical tape)
I'm extremely lucky when it comes to tools. I have access to both a wired and battery Dremel, and my dad's workplace has industrial-style tools. Plus, my dad knows a lot about electronics, so I can get advice when I need it.
Alright, so I'll post some pics to show just how bad it is right now.
This is my case opened up to show the size
And here's a close up of the mess. Yeah, pretty bad.
Today I'm working on putting the front panel window in.
This is my front bezel, removed. I disassembled it, and it's lying loose, which is why it looks like that. Makes sense, ne?
Here's a picture of the wire mess. Two LEDs are hooked up to the HD jack, and one is the power indicator. The power indicator will go behind a small reflective piece of plastic at the bottom of the window to reflect back up onto the drives.
Here's a picture of the bezel without the trim. Next to it is my victi... er, the acrylic I will be using. It's large enough that if I screw up, I have extra. Not bad for the smallest size Home Depot had.
Alright, that's it for now. I'll update later with the working pics of this stage.
~phantomditto
-Replacing fans
~phantomditto
