@/2ct!< said:Ok, you need to get a can of gloss overcoat as well. The Gloss of the paint goes to the top and essentially dissappears when you sand it flat, so you will need a clear gloss overcoat ( 2000 grit is not nearly smooth enought to produce shine on the product) unless of course you want a dullish, snowy finish instead. You can also not sand your last color coat, but it will be fairly smooth, but a lot of orange peel though.
It should be the same price as your regular paint, KRYLON should have some type. Look for "Crystal Clear Gloss" or the like, should be next to the colored paints and primers. Im guessing 1 can will be more than enough as well.phantomditto said:What price are we talking for this gloss overcoat? I'm intrigued.
By the way, for everybody else: I'm preparing to work on the window: I bought the new window tonight at Home Depot; Lowe's didn't have the size I needed.
~pd
Bboy_Jon said:what case is that? at first i thought it was a raidmax scorpio 868, but then i noticed you dont have a window and the usb ports and front mic and headphone jacks arent in the same spot as the raidmax cases, so ya what case is it?
id like to do something to my front door, i dont really like the lights all that much, i might put in a hole so i can turn it on without having to open the door
