more modding tonite. Tonite i got the ccfl switches mounted in the front of the case where the front usb/headphone jax used to be. I will eventually be putting led rocker switches in here but the ones that came with the ccfls will work for now. I also got everything in the case except the motherboard/proc/heatsink etc that hooks up the pci/agp bus. Wiring looks like it should turn out nice.
I also spent some more time on the led light strips. At one point i had them both not working and they seemed doomed. However i was able to recover most of them. I think long term i will be buying new ones. The long and short of it is that i am going to get this thing ready for the magazine thingy for the end of this weekend. And then i am going to continue working on this project and updating the project log... just more of a one update per week thing. mostly because i have an antec aria that will be taking main stage project log wise.
So on to the update:
you can see here how i mounted the ccfl switches in the front of the case. Nothing special this is a temp fix for some led rocker switches that will be comming in next week.
There is a little trap door that leads right to the ccfl switches. there was supposed to be a usb/headphone jack here but i made short work of that.
front of the case looking all nasty and secsie!
believe it or not that is all the power wires laid into place. The ones hanging are the 4 pin +12, the ATX connector and the Video card Connecter (which is on it's own wire/path from the powersupply) The only thing left to do wiring wise is to hook up the mobo and run all the little wires like matrix to mobo, and cpu/door fan wiring. Ive got one white ccfl along the bottom of the case, and one squeezed in there by the back exhaust fans. I had to file down the little square ccfl stand off things but it fits in there snugly.
Here is the concept art for the front fan grill... I was going to do this tonite but it got too late too fast and my screwing up on the led strips really ate up some time.
Things accomplished today:
1) mounted new ccfls.
2) mounted cd drives
3) wired 90 percent of all power wiring
4) finished led strip installation
5) drew up front fan grill
Left to do:
1) tint and attach main window
2) install board/proc
3) custom cut front fan grill
4) finish duct or air scoop for video card.
I wanted to do more tonite but i just screwed the led strips so bad i had to spend time to recover them. However the concept art for the front fan grill looks doable. Should be able to get that and the duct tomorow. I thought I would be getting the testors tinting spray today but that will be here tomorow as well. So that means tomorow is custom fan grill and tinting/mounting of main window day. That leaves thursday for installing the board and proc and finishing the duct. I will prob then spend friday afternoon finishing up all the loose ends.
That is it for now.
Prime
