- Jun 1, 2002
JudgeDredd said:I still want to know if burning in has a negative or positive affect.
if anything....it would be a positive thing to do.
mica
Darryl_D said:Ras you turkey got 8 stars already!!!! I hate you old man what do you live on these forums! Secondly umm the safe zone for northwood voltage is 1.85 volts no more!!! also this NSDSRPQVL whatever it is... DId you just make that up?
Rasputin'sLiver said:
heh heh, i know, i'm a big mouth. where 'ya been kid. we had an amd troll in here. you're nearly as good as sss at putting them in their place!
Darryl_D said:say hipro5 how loud is that delta? Didn't i tellya ras i was on vacation!
pacino said:When I spoke to Intel, one of their Engineers told me how the new northies, and he was refering to 533 bus aka "B" Side, don't like temps below 18c .. and he recommended "temps in between 20~28c" for good cooling.. Ras & Mica mentioned how frost mighta killed them, and I do believe that a combination of both, anything over 1.7 + extreme cooling = no B-northies will live. However, just a bit more about my experience with "A" northies, I had 2.2 and now 1.6, tested them both on the same setup as my smoked 2.26b and guess what? .. 2.2 did not die till I sold it (5months of uptime) and my 1.6 is on her 2nd week. B's are weak? sensitive? I don't know, but I'm not buying anotha 2.26 for sure!
dansonang said:water cooling will not real affect the chip as it is always near room or slightly lowers. it cools better than air as it can conduct more thermal energy per second from the Hsf. thats all
the thing i don't like about water cooling is that i fear leakage and condensation... but i guess if you're real careful...
Originally posted by FIZZ3
Condensation will not occur with watercooling. Leakage may, but the dangers can be controlled quite effectively, especially when using distilled (not very conductive) water.
Darryl_D said:
What's the fun in using distilled water?!!! Personally i feel a little electricity never hurt anyone.
you could always go for Prometeria or a Vapo... though i guess not everyone has got $600 lying around... and if i did i certainly wouldn't spend it on a vapo when i could build myself anotehr system with it!
SoL said:Mica im curious, what do you get when you run SiSoftware memory benchmark?
Thanks,
Briane
