- Apr 22, 2002
- Folding@Home in Ball Ground, GA
- Thread Starter
- #61
You can try either the stereo speaker wire or the telephone cable wire, but you might want to have both ready in case one turns out to be too big. The stereo speaker wire is generally 2 bundles of wire wrapped in plastic. Take one of the bundles and cut it open, and remove a single strand of wire from the bundle. Cut it about 1/4 inch long (you will need to verify the length when you install it). The jumper should look like this:
How many wires you need to install, and which holes in the socket you install them in, will depend on what your current default CPU voltage is and what you want to change it to.
