Here are my basic rough notes i took after i fixed the stuck POST. there are some redundancies. hopefully this can serve some purpose to someone someday.
overvolted 4790k to 1.8v @ x46 core multiplier
immediately boot into bios to reset to default voltage and clock after overvoltage/cpu high temp error msg
blue screen on win7 logo (possible cpu shutoff to preserve itself)
turn off ac power/disconnect/full power-drain
remove cmos battery/jump CLRTC pins 10 sec. replace battery and jumper to default.
board tries to post, gets stuck at Boot_Device_LED
peripherals being recognized, POST capable of reinitiation via ctrl+alt+del.
restart a few times, reseat gpu, cpu, RAM (different RAM configs made no difference in this recovery) disconnect/reconnect all power/drives.
clear CMOS RTC RAM again
now board getting stuck at DRAM_LED, self-restart loop begins, remove 2 sticks of ram forcing POST to acknolwedge memory swap, stuck at Boot_Device_LED again.
switched between individually connecting my three drives ssd,sshd,hdd (OS's installed on hdd and ssd) attempting to simplify boot options for board.
DRAM_LED again, add 2 sticks of RAM
Boot_Device_LED
power off, d/c all drives
power on, plug in ssd just before it reaches Boot_Device_LED.
Reinitiate, POST gets thru Boot_Device_LED!!!!
system boots into win7 thru integrated graphics HDMI port only.
Boot_Device_LED
