- Apr 12, 2002
MrNatural mate, what are you using to modify your BIOSes?
HeXaDeCiMaL said:Any chance of adding some more options to the memory voltage... 2.7V is a bit poor, my old KG7 have upto 3.0V... either that or a 4:3 CPU:MEM ratio would be nice
Thanks Mr N.
HeX.
Jirnsum said:I believe HeXaDeCiMaL was talking about Memory Voltages Mr. Natural
HeXaDeCiMaL said:As for the ratio, I mean that if the CPU is @ 133FSB the mem is @ 100Mhz therefore alowing higher overclocks of the CPU without being limited by the memory
HeXaDeCiMaL said:Fair enuf about the ratios, keep forgetting i'm on a P4 now and not a T-Bird
As for the 2.8V for memory, please implement it in the next one I know u may not see the need but when using my memory in other systems to get it stable @ higher than 150FSB I needed over 2.7V. At 166Mhz I needed 2.85V for it to be rock solid, anything lower wouldn't work.
HeXaDeCiMaL said:Just a thought, but do u think the fact that I am using ECC memory could effect the overclocking ability on this board???
Didn't effect it on the KG7, but as u say this is an INTEL chipset and therefore completely differnent...
I will get 2.4Ghz
HeX
rancid said:the new beta from abit for the bd7 suxors so bad.
they only add up to 1.7v for the cpu..
wont let me run my ram at 2.5,6,222 at 177fsb
it will change it back to 3333333 crapp and beep.
went back to mr natural's, h2 bios ..
2.7 250 fsb ram at 150 /300ddr
Randy
