GeIL Releases EVO SPEAR Phantom Gaming Edition DRAM
Just a few days ago, GeIL released a much-anticipated product in gaming memory called “EVO SPEAR Phantom Gaming Edition”. It is a collaboration with ASRock to provide a well-built level of compatibility with their top of the line Phantom Alliance motherboards. As you can see below there are two options to choose from, either for optimal use for AMD or Intel with multiple frequencies and capacities in each. Prices start at a decent $67.99 on Newegg, we couldn’t ask for more.
GeIL memory has joined forces with leading motherboard brand, ASRock, and its top-of-the-line Phantom Gaming Alliance. Through this partnership, GeIL and ASRock dedicated to building a strong foundation for compatibility and reliability between DRAM and motherboard. The EVO SPEAR Phantom Gaming Edition Memory is tested under the strict criteria and validation of the ASRock Phantom Gaming series motherboards. As an excellent result of the cooperation, exceptional stability has benefited. It’s available in frequencies from 2400MHz to 3200MHz, capacity for 4GB to 32GB kit, and runs as low as 1.2V and at max 1.35V.
As an influential member of the Phantom Gaming Alliance, the EVO SPEAR Phantom Gaming Edition Memory meant to let the visual elements of the modules become one for defining values of the co-branding. The module is built with a ten layer PCB and wrapped by a stealthy black aluminum heat spreader to deliver outstanding signal integrity and heat dissipation for gamers and enthusiasts who require better thermal conductivity for the small form factor systems (SFF). The EVO SPEAR Phantom Gaming Edition Memory offers a better choice for a cost-efficient upgrade, the exceptional gaming experience, video editing, and 3D animation rendering.
Backed by the limited lifetime warranty, the EVO SPEAR Phantom Gaming Edition Memory is fully compatible with ASRock Phantom Gaming Motherboards, including Intel Z390 Phantom Gaming X/9/8/7/6/4 series, AMD X570 Gaming X/4 series, AMD X399 Phantom Gaming 6 series and more. Most significantly, the EVO SPEAR Phantom Gaming Edition Memory is optimized for AMD platforms and strictly verified across a large number of AMD AM4 motherboards and AMD Ryzen processors to guarantee the best compatibility and stability for all AMD builders.
Loading new replies...
Avatar of BugFreak
BugFreak
2,470 messages 728 likes
Nice clean and simple look. Good to see manufacturers giving it up the big obnoxious heatsinks at times.
Reply Like
