Today, NZXT announced the H1 Mini-ITX Case that includes an SFX-L650W 80+ Gold PSU, 140mm AIO, and a PCIe riser card pre-installed. NZXT states that this will make for a simple building experience. The Hi Mini-ITX Case is the base for a higher-end pre-build option called the H1 Mini PC from NZXT BLD. NZXT states the value of their included components at $250.00 which comes close to our calculations. We came to about $80.00 for a comparable All-In-One, $125.00 for the Fractal Design Ion SFX 650G PSU, and $40.00 for a premium quality riser cable (~$245).
Read below for the official press release and more information from NZXT.
NZXT, a leading developer of software-powered hardware solutions for PC gaming, today announces the NZXT H1, a small form factor mini-ITX case that includes an SFX-L 650w 80+ Gold PSU, 140mm AIO, and PCIe riser card pre-installed for a simple building experience. In addition, the NZXT H1 is the focal point for a new high-end pre-build option for NZXT BLD called H1 Mini PC.
“Creating a small form factor case is something we have always wanted to improve upon because they are often challenging to build in and can hinder the performance of high-end hardware,” says Johnny Hou, Founder and CEO of NZXT. “That is why we simplified the building process and focused on performance when designing the NZXT H1. We set out to make this one of the easiest builds you can undertake while leaving no compromises when gaming.”
The NZXT H1 is a sleek, small, vertical chassis designed to fit elegantly in any battlestation, without limiting its gaming potential. Capable of housing most full-sized GPUs, the H1 was designed to effectively cool every component to prevent thermal throttling. Cable management is made easy with pre-routed cables and a rear-facing I/O on the bottom of the case which allows for simple cable clean-up.
The included components in the NZXT H1 (SFX-L 650w PSU, 140mm AIO, and Gen 3 PCIe riser card) represent over a $250 USD value, decreasing the number of items that a customer needs to purchase separately. Additionally, each included component is pre-installed, which saves time and makes the NZXT H1 one of the most simple cases to build in.
The NZXT BLD H1 Mini PC features an Intel Core I9 9900k and an Nvidia GeForce RTX 2070 Super Founder’s Edition, giving it the horsepower to the most demanding games. Each H1 Mini PC is backed by NZXT BLD’s 2 year warranty on parts and labor. All orders placed before 11 am PST ship the same day ordered.
H1 Features Sections
Small but Powerful
The compact vertical design provides a small spatial footprint while maintaining
support for most full-sized GPUs on the market so you can maintain your desk real estate without sacrificing graphics power.
A Simple Build
The toolless SSD tray and riser card are incredibly simple to install. In addition
to pre-routed cables, the motherboard I/O faces down, routing all cables
through the bottom of the case for a clean, simplified appearance.
Component Integration
Integrated power supply and AIO liquid cooler provide a better build
experience, along with pre-routed cables that make it easy to manage the
clutter and cut down on build time. An integrated PCIe riser* card is also
included for vertical GPU mounting. Included components are valued over $250 USD.
*PCIe riser compatible with Gen 3.0 PCIe GPUs
Elegant Airflow
The dual-chamber airflow is thermally designed to allow the CPU, GPU, and
PSU to pull in fresh air and exhaust hot air without affecting temperatures of
neighboring components.
MSRP Pricing
Price: $349.99 USD
Color Options:
Matte White
Matte Black
Availability:
USA: Now at NZXT.com
ROW: February
BLD: Now on LetsBLD.com
NZXT BLD H1 Mini PC Pre-build
Case: H1 (Black or White)
CPU: Intel Core i9 9900k
GPU: Nvidia Geforce RTX 2070 Super Founder’s EditionMotherboard: Asus ROG Strix Z390-I (Wi-Fi)
RAM: Team T-Force Vulcan Z 16GB 3200MHz
SDD: Intel 660p 1TB
PSU: 650W SFX- L 80 Plus Gold PSU
CPU Cooler: 140mm AIO
OS: Windows 10 Home Plus
MSRP: $1999.99
Availability
USA: Now at letsbld.com
About NZXT
Founded in 2004, NZXT is a leader of gaming products and services. Their award-winning products include computer cases, PC cooling solutions, RGB lighting kits, power supplies, and their free PC monitoring software, NZXT CAM. NZXT was created out of a passion for PC gaming and is dedicated to improving products and services to achieve extraordinary gaming experiences.
No replies yet
Loading new replies...
