Today, Cooler Master has announced the late March, early April release of the Cooler Master MasterLiquid ML120/240L RGB (Version 2) all-in-one liquid CPU Cooler. These are said to be an upgrade from the MasterLiquid ML120/240L RGB that was released in late 2017. Read on for Cooler Masters official Press Release.
Cooler Master, a global leader in designing and manufacturing innovative computer components, releases the MasterLiquid ML120/240L RGB (Version 2) all-in-one (AIO) liquid CPU cooler. Featuring a newly designed dual-chamber pump and the newest iteration of the SickleFlow 120 RGB individual fans, the MasterLiquid ML120/240L V2 introduces a new generation of cooling solutions.
3rd Generation Dual Chamber Pump & Enlarged Radiator Design
The MasterLiquid ML120/240L V2 includes a newly designed dual-chamber pump and overall enlarged radiator surface area that improves overall heat dissipation, airflow, and liquid cooling efficiency.
Updated Sickleflow 120 RGB
The MasterLiquid ML120/240L V2 features the latest SickleFlow 120 RGB fan, equipped with a refreshed exterior design and Air Balance 2.0 fan blades to improve overall performance and airflow as well as enhanced lighting effects.
ML240L V2
Reinforced Protection
Upgrade EPDM rubber used in the pump that has industrial properties with higher tempreture and pressure thresholds to prevent all phases of thermal solution emissions.
The MasterLiquid ML120/240L V2 will be available late March-early April at select retailers, including Amazon and Newegg, for $69.99 (ML120L) and $79.99 (ML240L).
Loading new replies...
