Today, XPG launched the second generation of its All-in-One liquid cooler, the XPG Levante 360. The new AIO uses Asetek’s 7th generation pump and a large 360mm radiator and a ‘thermally optimized’ copper plate with 0.15 mm-thin microchannels to dissipate the heat. XPG equipped the Levante 360 with three Dual Ring 120mm fans (40K hours at 40°C MTBF) to move air through the radiator. Each fan sports twenty RGBs along with the pump cap that is also lit up with RGB lighting. Backed by a 5-year warranty, the XPG Levante has an MSRP of $179.99 and backed by a 5-year warranty. You’ll find these on store shelves/online on December 12th, 2020.
Read the press release below for more information.
XPG Launches LEVANTE 360 All-in-OneLiquid Cooler
Taipei, Taiwan – December3, 2020 – XPG, a fast growing provider of systems, components, and peripherals for Gamers, Esports Pros, and Tech Enthusiasts, is pleased to announce the second iteration of its All-in-One Liquid Cooler products with the XPG LEVANTE 360.
XPG LEVANTE 360 Cooler – The latest Asetek Cooling Solution in collaboration with XPG
XPG LEVANTE 360 is a 3 fans all-in-one CPU liquid cooler that sports Asetek’s industry-leading solution, the 7th generation Asetek®pump technology and a dazzling design that brings a lot of personality to the front cover of your next gaming chassis build.
High-Performance Cooling
Asetek®7th generation patented cooling solutions include a pump with PWN control feature, to ensure the best optimal CPU temperature management, together with a massive 360mm radiator and a thermal-optimized copper plate with just 0.15mm-thin microchannels to offer a larger surface area for boosted heat exchange efficiency. XPG has equipped the XPG LEVANTE 360 with three vibrant Dual Ring 120mm fans employing a Fluid Dynamic Bearing (FDB) motor design and 4-pin Pulse Width Modulation (PWM). FDB fans with PWM are designed with an auto-restart mechanism and they are optimized for reliability (up to 40,000 hours at 40ºC of MTBF) and minimize noise at 34 dB when on full cycle with high airflow (61.5CFM).
Dazzling RGB to complement the best Gaming Builds
For stunning flair, each of the fans comes built-in with twenty RGB LEDs, while the liquid pump cap is also illuminated with RGB lighting. For those who don’t prefer using the ARGB connector linked directly to their motherboard of choice and the related software control (most major brands supported) an additional ARGB controller is included, which can also be used to allows users to easily adjust pre-programmed light modes, speeds & brightness of both RGB fans & the liquid pump’s RGB cap.
XPG LEVANTE 360 high quality is backed by a 5 years warranty, which is one of the highest claims in the industry. To find out about availability and prices in specific markets, please contact your nearest XPG representative via www.xpg.com.
Availability
XPG LEVANTE 360 will be available on 12/12/20.
Page
XPG LEVANTE 360
https://www.xpg.com/us/feature/709/
MSRP
XPG LEVANTE 360
$179.99
Joe Shields (Earthdog)
No replies yet
Loading new replies...
