Table of Contents
Today we get an opportunity to look at another M.2 NVMe-based SSD in the XPG Spectrix S40G RGB. The Spectrix series of drives are different than most with XPG adding controllable RGB LEDs to accommodate today’s trend. The modules are spec’d to reach speeds up to 3500 MB/s sequential reads and 3000 MB/s on writes, which on paper, places it up there with other enthusiast level drives.
These are impressive numbers and should be a winning combination of looks and performance at a remarkable price point. We’ll be putting the drive through our testing suite and will soon know if the paper specs match up with actual results. Read on to see how the XPG Spextrix S40G RGB compares to similarly rated drives.
Specifications and Features of the XPG Spectrix S40G RGB SSDXPG Spectrix S40G RGBXPG Spectrix S40G RGB
The XPG Spectrix S40G series comes in four capacities – 256 GB, 512 GB, 1 TB, and 2 TB, with performance scaling up as the capacity increases. For example, the 256 GB drive is rated at 3500/1200 MB/s Reads/Writes with 210K/230K IOPS while the 1 TB and 2 TB models run 3500/3000 MB/s with 290K/240K IOPS (according to ADATA’s internal testing using Cystal Disk Mark).
This is a new drive from XPG, which uses the latest Realtek RTS5762 controller and pairs it with Micron 3D TLC NAND. It was difficult to find specifics on which NAND from Micron this drive will use, but from what we gathered, it could be 64 or 96-layer depending on availability.
The XPG Spectrix S40G drives all come in a 2280 size and uses both sides of the PCB depending on the capacity. The 1 TB model we have here has storage modules and a NANYA DRAM module (128 MB total through a 1Gb IC) on one side, while the other side of the drive has the controller and storage modules.
In addition to the new internals, the Spectrix S40G is sporting a new heatsink with integrated RGB LED lighting that is compatible with RGB lighting control apps from the major motherboard manufacturers. The heatsink can not be removed without voiding the manufacturer’s warranty, but that kind of defeats the purpose of having the RGB LED in the first place.
On the software side of things, the XPG Spectrix S40G supports Low-Density Parity Check (LDPC) error-correcting technology, which XPG says can detect and fix a more extensive range of data errors for more accurate data transfers and a longer SSD lifespan. In addition, the S40G supports AES 256-bit encryption to ensure data security and integrity.
XPG Spectrix S40G RGB M.2 NVMe SSD Specifications | |
Capacity | 256 GB / 512 GB / 1 TB / 2 TB |
Interface | NVMe 1.3 PCIe 3.0 x4 |
Controller | Realtek RTS5762 |
Flash | Micron 3D TLC |
Form Factor | Double-sided M.2 2280 M Key |
Dimensions (LxWxH) | 80 x 22 x 8 mm |
DRAM Cache | 128 MB |
Sequential Read/Write Speeds | Read: 2800-3500 MB/s Write: 1200-3000 MB/s |
4KB Random Read / Write (QD32) | 210k-300k IOPS 230k-240k IOPS |
Active / Idle Power | .33 W (typical) / .14 mW (slumber) |
Service & Support | 5 Years |
Endurance / MTBF | 2 TB – 1280 TBW 1 TB -640 TBW 512 GB – 320 TBW 256 GB – 160 TBW2,000,000 hours MTBF |
Pricing | 2 TB – $269.99 1 TB – $152.99 512 GB – $104.90 256 GB- $59.99 |
XCPG Spectrix S40G RGB Packaging/Product Tour
As you can see in the system picture above the RGB LED lighting is quite bright. This was taken on the MSI MEG X570 which has its own heatsinks but the XPG Spectrix S40G RGB looks much better.
From the slideshow above, users can see the packaging for the S40G has a picture of the Spectrix S40G front and center with the model name and some details such as capacity and interface around the edges. Opening the flap at the side, we can slide the plastic container out, which holds the drive tightly, keeping it secure for shipping.
Our first look at the drive shows its heat spreader attached and looking good hiding the ICs. After flipping it over, exposes a DRAM cache chip and, hidden under the label, more ADATA storage modules. Removing the heatsink revealed the Realtek controller and additional ADATA labeled storage ICs.
The pictures above are close-ups of the Realtek RTS5762 controller, ADATA labeled 3D TLC NAND, as well as the NANYA DDR3L DRAM Cache IC, which is only 128 MB in capacity.
The following video came from the XPG Spectrix S40G product page:
Software
XPG also includes access to free software, which will optimize and show the status of the drive in the system. This software comes from its parent company in the form of ADATA’s SSD ToolBox. They also offer access to Acronis True Image HD to image your current drive making a swap-out nearly painless. You will find the XPG RGB control software at the previous link in the download section.
The SSD Toolbox is a complete utility used to monitor as well as optimize the drive. The software runs diagnostics (both a quick and ‘full’ diagnostic), sets temperature and capacity alerts, has Secure Erase capabilities, as well as system optimizations, which include adjusting settings for Superfetch, Prefetch, and automatic defragmentation abilities. Overall it keeps an eye on the drive and will help set up your operating system for peak performance with the drive. In my limited use with the software, it worked as described. We have also included a screenshot of the XPG RGB lighting utility and ASUS Aura software in the above slideshow as you can see the Aura utility recognized the drive and controlled the lighting easily.
Test System and Test Methods
We install the drive as a secondary device on the test system and run the listed benchmarks against it. While typically many will use these drives as system drives, the test machines can be different as well as people’s OS implementation in the first place, so we try to isolate as many variables as possible in an effort to have the results as repeatable as possible with any reviewer who may test drives.
For this review, we also tested the XPG Spectrix S40G on the new AMD X570 platform, which utilizes PCIe 4.0 to see if the more modern protocol would show any limitations placed on the controller because of PCIe 3.0 transfer speeds. This will also show differences in platform storage capabilities.
Below are the tests we run with a brief description.
- Crystal Disk Mark v 7.0.0 x64 – Run at Default Settings (5 Passes)
- AS SSD v 2.0.6485 – Run at Default Settings
- ATTO v 3.05 – Run at Default Settings except for the QD Set to 10
- Anvil Storage Utility Benchmark v 1.1.0 – Default Settings
PCIe 3.0 Test System Components | |
Motherboard | ASUS ROG Maximus X Apex |
CPU | Intel i7 8700K |
CPU Cooler | EVGA CLC 240 |
Memory | 2×8 GB G.Skill Trident Z 3200 MHz CL15-15-15-35 |
SSD | Toshiba OCZ TR200 480 GB (OS), XPG Spectrix S40G RGB 1 TB |
Power Supply | EVGA 750W G3 |
Video Card | AMD Radeon RX 5700 XT |
PCIe 4.0 AMD Test System Components | |
Motherboard | MSI X570 MEG GODLIKE |
CPU | AMD Ryzen R9 3900X PBO |
Memory | 2×8 GB G.Skill Royal 3600 MHz CL16-16-16-36 |
A special thanks go out to EVGA for providing the CLC 240 CPU Cooler and 750W G3 Power Supply to cool and power the system, G.Skill for the Trident Z DRAM, and Toshiba OCZ for the 480GB TR200 SSDs storage running the OS, benchmarks, and games. With our partners helping out, we can build matching test systems to mitigate any differences found between using different hardware. This allows for multiple reviewers in different locations to use the same test system and compare results between reviewers minimizing system variance.
Performance XPG Spectrix S40G RGB
CrystalDiskMark
In our first test, Crystal Disk Mark (CDM) reads, the S40G performed well in the first sequential read test, hitting its rated speed with 3563 MB/s but drops back down to the low end of the pack results with lower queue depths. 4K reads are about half the rate of the other drives, but keep in mind they’re much more expensive than the XPG Spectrix S40G.
On the writes side of CDM, again, we see solid performance in the first sequential test coming in at 2708 MB/s, which is still a bit shy of its rated write speeds but besting the Samsung 970 Pro which is twice the price. It is interesting that the PCIe 4.0 protocol gives the S40G a boost in the lower queue depths for both the read and write tests and more than doubles the random 4K writes.
AS SSD
In AS SSD, the S40G shined in the sequential read test. It also did well in the single thread 4K read and write tests. While sequential throughput is important, the vast majority of files are much smaller, so 4K performance is an essential metric on how well the drives perform daily. When comparing to the other much more expensive drives, we can see the difference that having a large DRAM buffer can make. The Samsung and Gigabyte drives with 2 GB DDR3 and 1 GB DDR4 respectively had a definite advantage. Still, the Gigabyte PCIe 4.0 drive seems to have done exceptionally well on both platforms leveraging the faster controller.
Access times in AS SSD were lacking, in particular, the write times, which leads to the overall score. The XPG Spectrix S40G managed a mid-range score. AS SSD, in particular, seems to be a tough nut for the S40G likely due to the use of incompressible data.
ATTO
In ATTO, the XPG Spectrix S40G does well, particularly in the read testing trading blows with the Samsung 970 Pro on the larger files. Looking at the write results, however, we notice that once again, the Spectrix S40G isn’t coming close to its rated read speeds. What is interesting though, is the 16K and smaller files the S40G is performed surprisingly well beating the 970 Pro.
In our Anvil Storage Utility results, the S40G scored 11,271, which is more of a mid-range result than an enthusiast-level of performance.
Conclusion
The Spectrix S40G RGB is an M.2 NVMe drive aimed at gamers and enthusiasts looking for that little bit extra in the bling department. The S40G also looks very impressive on paper with 3500 MB/s read, and 3000 MB/s write speeds, AES 256-bit encryption, and a 5-year warranty. Add to that a stylish RGB LED heat sink that can be customized to accent your system, and we have a nice all-around enthusiast-level drive with performance and looks.
The reality is the XPG Spectrix S40G RGB only performed well during specific tests and rarely came close to its rated write speeds, overall when comparing Anvil benchmark scores, it was on the lower end of the scale. The combination of the Realtek controller and anemic 128 MB of DRAM cache didn’t do the Spectrix S40G any favors. Testing it against the Samsung 970 Pro and the Gigabyte Gen 4.0 drives in retrospect seems unfair, but those choices were made based on XPG’s ratings for the drive.
To be fair, the Spectrix S40G RGB SSD is in a completely different price category compared to the other two drives. Available at Newegg for $152.99, that’s $ 100 less than the Gigabyte and a full $200 less than the Samsung, but there are many drives in this price range with better performance, such as XPG’s own Gammix S11 Pro for $139.99. What you’re not getting is the RGB LED heat spreader.
The XPG Spectrix S40G RGB does give you decent performance at a reasonable price; what sets it apart is the RGB lighting. Given that it’s one of the few drives available with customizable RGB LEDs makes it easier to overlook the mediocre performance and still give it the “Approved” award.
– Shawn Jennings (Johan45)
Loading new replies...
