Good day everyone.
3800x
Asus tuf x570
Corsair vengeance rgb pro 3200mhz c16 b-die downbin. Running at 3200 16 17 17 17 35 1t. Ryzen calculator didn't work at all.
Sabrent 1tb m.2 .
Hyperx 240gb ssd x2
One 360 open loop rad would have been enough really. Each extra rad only dropped cpu temp about 2-3c.
Msi 2070 ventus.
Open loop. Dcc 3.25. Ek supremacy. Darkside rads. 360, 240, super thick 240. 15 120mm pressure fans. 3 140mm fans .
Everything in push pull. And case fans to blow extra air in.
Corsair 780t white.
Evga 850 gold.
So 4.4ghz prime stable avx and everything, cinebench, memtest ,games bfv metro at 1.256 in bios. Llc 4 to stop vdroop. Going to see if can run llc at 3 but so far lowest i can go.
So got the ultimate golden chip.
According to gamers nexus video of safe voltage. I technically could be 0.2 higher if measured on the board.
In which case my golden chip is just a regular ol 3800x.
So overclocking gurus and electronics specialists where do i measure vcore on the board. Not a 800 dollar board with actual spots for measurements. Where do i look?? Thx very much.
3800x
Asus tuf x570
Sabrent 1tb m.2 .
Hyperx 240gb ssd x2
Msi 2070 ventus.
Corsair 780t white.
Evga 850 gold.
