@RGone .... Was just answering his question on the MSI board he had asked.
@coolerman
Like RGone says I will answer your questions as best I can but I do tell it like it is, sometimes too much so, gotta work on that
The problem with the Closed loop systems is thay can only remove so much heat from the chip and they do absolutly nothing to help your temps in your motherboard. Yes I have 3 of them here too .... H70, H100 and K920. The thermaltake cooler you are using is pretty much the same cooler and made by the same company that makes the antec closed loop systems. Thier new one .... supposed to be a couple *C better then the H100 .....
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835106190
has some potential and was reviewd by Buckeye here in the watercooling section .....
http://www.overclockers.com/forums/showthread.php?t=717167
If you look at the thread RGone posted and my cooling system I am using I was getting up around 65*C Core Temps @ 4500MHZ and and over 70*C on my socket Temps before I really understood what it took to cool this puppy and I am still learning. That was with a 280 Black Ice Extream and a 240 Black Ice Extream rad in the sytem. I have said it before these puppies generate allot of heat and it is not easy to deal with it.
It cost me another $300 - $400 to make a few changes that really helped my temps to gain another 200MHZ I can't get passed 4716MHZ only about 30 min Stable without my temps going where I don't want them to. Mind you my temps are way better now at that 4700MHZ.
You are not the first person to come here with the same questions, we have a few open threads here of people just like you that have found it very hard to OC these CPU's and
deal with the heat. Two more brand new threads just today since I went to work this am. We spent allot of time with GamerMagnet who did the same as you and bought a closed loop Antec Khuler 920 and had the exact same results as you did / are having right now.
Now that all being said we will help you get the best OC we can out of your system. I hope I wasn't too blunt on how I worded this, it wasn't meant to be critical and maybe I am just venting .... I just spent the whole day dealling with a bunch of Idiot drivers. I need a BEER or two.
