- Mar 7, 2008
only time will tell. If i had to guess, most of the headroom gained went i to raising the clocks 200-300 mhz and fitting under the same tdp. Ill bet these cant get past their xfr either... but do hope i am wrong.
I haven't played with Ryzen "X" CPUs, but my understanding was that short of extreme cooling, they're not pushing much past their turbo speeds either? 4.1-ish or may be a little more? I know mine was an assumption on top of an assumption, but if 1700X and 2700X occupy the same relative positioning, there's still a higher 2800X to come to better indicate the eventual typical maximum clocks. So with a huge grain of salt on standby, my assumption is a Ryzen 2000 CPU will, if pushed to the edge, may hit around 4.5. I don't know about you, but for benching that should pump out some nice numbers. Even if you stick to a slightly lower clock for 24/7 running, that largely negates the perceived clock disadvantage relative to Intel on the higher end consumer side.
