- May 23, 2014
- Miami, FL.
Sort of. The 'boost' clock is only on a couple of cores. You can overclock all cores to that speed with some luck. AMD cpus cant really get past that.unless i misunderstand it seem like the new amd processors act like video cards reaching max speed if cooled well enough. has anyone seen the max speed of a stock chip with temps completely under control with a water cooler or a big tower heatsink? according to amd 4.3ghz is stock speed if temps are low enough. doesn't this make overclocking semi pointless?
Basically yes. So long as the CPU is within a predefined thermal margin it will clock itself up to its maximum speed.
Just a bit of clarification on the new iteration of AMD's performance boost. It does work quite a bit differently than it did on the release of Ryzen. Initially, if you take the 1800X as and example, it had a base clock speed of 3.6 GHz(3.7 XFR) but the boost only really worked on two cores up to 4.1 GHz. Now with ZEN + the 2700X has a base speed of 3.7, all core boost up to 4.0 during stability testing and up to two cores will hit 4.35 GHz. XFR this tim around only seems to add about 50 MHz. AMD has also included the option ( Performance Boost Overdrive) which will let you adjust the all-core boost up to the limit of your cooling. So in a sense that was correct Brando, it just doesn't do it on it's own. I found it very simple though, didn't alter any voltages just raised the boost level and the system ran stable up to 4200 MHz
Yeah AMD is definitely improving. This time next year should (hopefully) be much more exciting when they do a full makeover and die shrink to 7nm. If they can get the core speeds up to 4.8 ish. Intel will have their hands full. They might be slightly behind on IPC (which should also be improved) but their SMT is much more efficient in most cases, pair that with on par core speed, that should leave a pretty even playing field. Then it comes down to price which has always been AMD's strongest lure lately.
