so you are complaining about it not using more ?
What resolution are you running?
Can you be more clear with High + Vista options?
Vista = Very High, so you either have everything on High, everything on Very High, or some of each.
I'm running at 1680x1050, and when I turn it to 16xQ w/ my OC'd GTX and Q6600 @ 3.6Ghz, I'm only getting around 15-20FPS. I find it hard to believe you are using 16xQ with a 320MB GTS and it is "playable" with things turned up more than "High" unless you are running a low resolution.
It might be, but I still don't think an 8800GTS 320MB can handle it at any decent resolution and still be playable.
After messing around for awhile, I lowered all my settings to medium on 1280x960 to get rid of that ridiculous studdering issue when turning and sure enough, it got rid of it entirely. It's a much more enjoyable playing experience now and to be completely honest, I don't notice too much of a difference graphics wise....running on all high settings, 16Q AA, on 1280x1024.
I get about 30fps avg on 1152x864 and is VERY playable)
This isnt accurate at all.
I am running 1600x1200 on all High settings with 2xAA. Perfectly playable and no stuttering.
if you read back he isn't using 16xQ, but Tyranos is.
I should make a list of those people I believe and those I don't.
rainless: I believe.
I run 1280x720
Combination of high/very high changed config files. 35-40FPS using DX10 under Vista. Key here is Vista since this game does run slower in Vista at least wiht ATI cards now, not sure how the newer nVidia driver helps out.
Total crap.
Yea, I don't know enough about ATI's cards to have any idea of what to expect with your card.
What about AA?
lol, I don't really need to provide SS because I can honestly care less if people don't believe me, but I'll see what I can do
oh and if I really wanted to lie, it wouldn't be that hard to put 2 numbers on the corner of the screen on photoshop
i'll go ingame on XP and Vista and take few screenshots for you, but Vista doesn't have fraps installed, so i'll take a pic of the benchmark
