Not real surprised that you have a quick BSOD.
1. Your DDR3-1333 ram is running at DDR3-1441
2. Your ram timings at DDR3-1333 are supposed to be 9, 9, 9, 24, 33
but you have them at the faster overclocked speed set to 8, 8, 8, 20, 27 and 1T where 2T
is often easeir with AMD setups. My mobo actually shows faster at 2T in MaxMem.
3. So you need to at least loosen the timings to the recommended settings and REtest.
The ram may not lke the DDR3-1441 speed, but it might do it with the more correct timings.
4. I also notice the HT Link speed is up to 2161.47Mhz and that might be too high for that Deneb processor.
Some don't like to be overclocked much over their 2,000Mhz default speed.
5. And if you are going to run 2431.7Mhz for the CPU_NB speed, you may need to raise the
CPU_NB voltage into the 1.25V range or sometimes even a little more.
RGone...
