I calculated my hardware's wattage and 298watts is all I need.axess68 said:You're using only a 350w PSU?? Wow! I'm using a 500w Antec Smartpower 2.0. I guess it should be ok then!
Thank you. But not happy.amdextreme said:Good Job, soon i should be getting my mobo,,,
ochungry said:I calculated my hardware's wattage and 298watts is all I need.
I have been using this psu for 6 months and it hasn't faield me yet. AMD specifies min 25watts for 12v rail, and this one is dual 12v rails totaling 29watts.
My agp card does not draw much power, and any video card under 85watts,
should work fine.
axess68 said:My power supply has dual 12v Rails as well. One cable is specifically marked PCI-Express. The outputs are 17A and 19A respectively. The stats for my specific PSU are here: http://www.antec.com/specs/SP500_spe.html
Does that look like it will do ok for the new board and a PCI-Express card eventually?
UPDATE: I ran the PSU Calculator and it said that I need 287w of power minimum. So, I guess I'm ok.
would i be able to use this Hard Drive with this Mobo
http://www.newegg.com/Product/Produ...N82E16822144414
Yep, this motherboard is SATAII ready.rox1co said:would i be able to use this Hard Drive with this Mobo
http://www.newegg.com/Product/Product.asp?Item=N82E16822144414
You probably won't notice a great difference in performance, provided the only thing you change is the processor. And if you don't use AGP or PCIe than I guess your only choice left would be PCI.well still waiting for my Asrock board and 939 socket Athlon 64 3000+ processor, should be here tomorrow according to Fed Ex, been thinking, right now i have the MSI k8T Neo fsr board with 754 socket Athlon 64 2800+, would this really be an upgrade from the MSI board, being the MSI was a little more money too. wondering if there will be an increase in speed as well, what are my options besides the agp and pci express options, been reading alot on this topic, but still am a little confused, hmmmm...
To be as gentle as possible, what I think is thatfunkycoldmedina said:<SNIP>What do you think about this?<SNIP>
