- Sep 17, 2004
Thanks Karl Pell, but those are the exact drivers that are giving me the SCSI info. Will be gone for work all day today so I"ll figure it out when I get home. Learning experience.
On my A8V Deluxe mobo, IDE operating mode for a SATA controller is the correct choice if using individual SATA drives, i.e. no RAID array. IDE mode doesn't mean that your SATA drive is operating any slower than it should be. Does the computer boot from your SATA drive if you leave the operating mode on IDE? If so, then it's working fine.RangerStew said:Hey all,
Mobo got here today, along with the Hitachi Desktar 80GB SATA II HD. Have a problem though. The only way the mobo will recognize the HD is if it is running in IDE mode. So I installed WinXP onto that way. Once I had XP on it, I used the driver CD that came with the mobo to install the SATA II drivers. I restarted and changed it back to SATA mode in the BIOS. It booted up, but when it got to XP it tells me I have a SCSI HD! Not sure what is going on. I tried to follow the manuals instructions on installing the HD in SATA mode, but with no luck. Anyone else have similar issues?
Ps. Im a noob when it comes to HDs(always used regular ATA in the past) so forgive me for this question: How can you tell how fast your HD is running, as in how many mbps it is going?
KillrBuckeye said:No, no, no! This is the mistake I made when putting together my new system, and it wouldn't turn on! See this thread.
There should be another square 4-pin plug on your PSU. Use that one.
HighFlowRod said:Hey guys, I'm having some overclocking problems. I've updated the bios to 1.2 and I can't overclock. I go into bios and set the multiplier higher, save changes, and when I boot into windows and exe cpu z it says I'm runing 1.8Ghz (I have a Venice 3000+). Look at my specs and please give me a hand.
amdextreme said:have you tried setting your FSB settings??
and also...just to make sure you might want to try another cpu info. program, here is a link to a few,,http://www.majorgeeks.com/download.php?id=9&sort=25
This confuses me. I'm at the same speed 270*9 1:1 with RAM yet your mem outscores me. Is it because I'm putting more of a strain on the mem controller?ochungry said:Ok I am back. Right now I am @ 9x270=2430mhz. <snip>
http://img353.imageshack.us/my.php?image=100720051655100dz.jpg
ochungry said:<snip>
A Tip- The NB and SB links speed (HTT) is directly proportional
to the CPU fsb. The final HTT should be close to 1000-1150mhz.
Here is the ratio. HTT is 5x200=1000mhz. So if you choose 800 HTT in setting,
the ratio would be 800/1000=0.8, multiply it by your new CPU fsb:
0.8x270=216, multiplied by 5=1080mhz, final HTT.
Formula: new HTT=(HTT setting/1000) x (new CPU fsb) x (5)[/LEFT]
Edited: So Sorry for bad link. I just noticed and now f...ing above is using the 4X divider not the 5X.
The "High" setting was measured by NPlack @ Rebel's Haven and it was putting out 2.71v.LordDarik said:Has anyone used high voltage RAM with this board? I'm wanting to run some Crucial Ballistix in it but don't know if the voltage will be good enough.
amdextreme said:hello all, anyone know of any temp monitoring software that will work with this mobo, thanks.......
