- Jan 7, 2005
Probably the same as your Opteron, if not less. Just remember, no PCI locks on this board, you OC the processor, you OC everything else as well.
I started out with this board and it's a solid board. Run Prime95 for 24 hours, that will get you the stability check you want.
If your RAMS need much more than 2.7v to overclock, you'll have a problem soon. The board at only puts out ~2.7 volts vdimm without mods and about 2.65v under load. Set your vdimm in the BIOS on "high" (~2.7v). Vcore usually isn't a problem, it's a decent board but it's not an overclockers dream with its limitations on voltage.
I ran Ballistix on this board for about 6 weeks then began getting error messages. The Ballistix RAMS were ok but they required 2.8v which I couldn't give them until I had mods done. So if you begin getting error messages, it may not be the RAMs. Run a 5/6 divider if you can, that should cure vdimm voltages.
