- Jun 1, 2013
- Thread Starter
- #121
I have looked at your case, I dont' see a mount for the h100 rad any place, are you sure it will fit?
Rebooting and testing. I thought all it needed was 2 120mm fan slots. On the left panel it can hold 6
that is your access panel, you will have dismount and remount it every time you touch the thing.
that sounds like a bunch of work just to reset the cmos or change some ram.
ok, lets save that to the next profile and try for the magic 4.5, thats a full ghz over stock.
Testing now.
I wonder if theres a way to make sure if itd fit?
you have that saved as a profile in the bios???????
in the bios and not in ai suite?????????
then, go here and download gpu-z.
install both.
i saw it and added it
