- Jan 10, 2012
please reread post# 147.
ok, we are now fully overclocked.
in aquamark, look at the cpu score 23284/23382, it improved.
lower the cpu clock .5 then raise the target cpu speed to 4.6 with the fsb and run it and post it. do this till it crashes then back the fsb back 2.
I will look in tuesday, good night.
There's a good Nvidia forum for the cards. What seems to be the problem?
With the new memory you will have to set the timings and frequency manually, assuming that you're probably getting something faster. When you first install it, go into bios right a way and set the frequency, voltage and the main timings. It should start right up afterwards.
If you have the ram model # you can find the spec at the site. There should be something on a sticker or other that's included with the ram. The first four setting, command rate and voltage are the important ones.
Sli can be tricky. Have you updated drivers since then. If so you need to re-enable the sli in Nvidia control panel. I can give you some help if you like> Check the control panel first and make sure 1. that SLI is available and 2. it's enabled.
I just checked further back and your gpuz is showing 2 cards enabled. Do you have another bridge you can try?
I added this after. Also double check power connections
Not likely that one is dead. Double check connections and make sure they're seated. You didn't put them in different slots did you? You have to have them in 1 and 3 on that board. Download heaven 4.0 and do a run with SLI and one without see what kind of difference it shows.
You really never have told me if you changed drivers any time in there. They really do make a huge difference. Nvidia like AMD has adopted a one driver fits all mentality. Your cards are 4 generations old. The newer drivers are typically optimized for newer hardware and game titles. I have a collection of "My favourite drivers" and I always keep them around.
If you haven't installed any drivers since your cpu update then maybe you should. Drivers can be very quirky and most of the time they're at the root of the problem.
Just for arguments sake. Download driver sweeper, Uninstall your current drivers andd restart in safe mode then run driver sweeper and remove the display, physx and hd audio basically anything that comes in the driver packsge the 3d stuff too. . Restart and reinstall ( I do a custom install and deselect the audio and 3d stuff my audio goes through the board and 3d well....). your drivers. See if that helps.
