It is also 300 bucks . I like the 830 betterHeya, the stacker is nice, but you might want to give this a look before deciding: http://www.newegg.com/Product/Product.aspx?Item=N82E16811163057
Probably the best looking case available today. Has plenty of quiet fans, active cooling over the hard drives, will hold 2 PSUs, well, just take a look. It's a work of art.
There's also a window version for 10 bucks more: http://www.newegg.com/Product/Product.aspx?Item=N82E16811163068
Mesh won't be a problem, any "fan grills" are immediately getting removedI see you are considering the Stacker 830, and that's what I would recommend. I've probably owned 10 different cases since I've been into the whole PC building thing, and this is, by far, the best case I've ever used. It's nice looking, has TONS of room, great cooling, pretty much everything I could ever want in a case. The only thing I can think of to complain about is it can be a little loud, since the sides are mesh. But, I have all my fans running through a fan controller, so they can be turned down when I'm not gaming/benching/whatever. Oh, and the side panels are a little difficult to put on/take off at first, but once you get the hang of it, it will not be an issue.
Yup yupYou still haven't bought a case?!??! Shesh, you're worse than I am.
I'm sure the case is nice, but it is irrelevant since that case is over my 300 "limit" that I set in place for myself.It took me forever to decide, finally bit the bullet on the Silverstone TJ10...Just wait I should have it next week..I'll post pics, It's pretty impressive IMO
That would be awesome if you could tell me anything you find wrong with it. I don't want to get one where someone stripped all the holes >.>refurbed, I just ordered the refurb 830 should be here in a week.
Scratches are no problem, it is getting painted.
Put your monitor really close. I might have to squint, but whatever works.As soon as it comes I will post whats wrong with it if anything is, cant take pics though i dont have a camera.
