- Thread Starter
- #81
I figured I could get atleast a stabkle 3.6ghz OC with the Hyper TX3.. I wet sanded the bottom. Used 800 grit automotive sandpapaer. Polished it and now there are no machine marks. It's a flat surface. Maybe just a little line on each side of the copper pippes. I took a smaller fan and made it blow directly on the heatpipes before it gets to the fins. Right now I'm at 1.216 vcore at 3.37ghz stable. CPU socket temps are about 48ish and core temps at 40ish. I could push a bit more but I'm gonna wait for my water cooling to come in
Im at 225 x 15. My RAM is dual channel at 1800mhz and NB at 2250.
I know how to overclock with a locked multi. And like I said before with Gigabytes F10b bios it shows the frequencies in gray when you make a chance in multi or fsb prior to saving. I'm starting to get a hang of it.
From what i've read most can get the FSB to 265 with the right cooling and voltage increase. I figued 1.35-1.4 hopefully will get me to 265 x 17 for a 4.5ghz OC, and I'll adjust other settings accordingly. I don't want to get this thing vcore with this Hyper TX3. It's only 92mm push pull. I'd fry my chip in seconds
