With the impending release of Nvidia’s latest video cards, Alphacool has released a water block designed to fit on various models of RTX 3080 and RTX 3090 graphics cards. The new block focused on performance improvements reducing the thermal pads to 1 mm and the nickel-plated copper block was made thinner (down to 5.5 mm from 7 mm). Water flow was also said to be improved.
On the design front, the Eisblock Aurora Plex GPX-N brings the embedded RGB LED lighting more to the foreground. This and other design changes are said to result in better light scattering in the water because of the reflections of the changed design.
The Eisblock Aurora Plex GPX-N is available now priced at 119.99€ (~$143.00 USD). Below you’ll find the Alphacool Press Release.
Alphacool presents the Eisblock Aurora Plexi GPX-N cooler for reference design Nvidia RTX 3080 and 3090 graphics cards. The cooler offers outstanding cooling performance thanks to its full cover design. The new backplate, which is delivered together with the cooler, also contributes to this. This stabilizes the graphics card and ensures an even contact along the whole cooler. The water block cold plate is made of nickel-plated copper. The cooler covers all relevant components such as voltage converters and the graphics memory.
The Alphacool Eisblock GPX-N Aurora Plexi has an LED strip across the entire width with addressable 5V digital RGB LEDs. These illuminate the entire cooler homogeneously and ensures an outstanding ambience in the PC housing.
Compatibility list:
ATTENTION: The following models were visually checked for compatibility. Please note that this list may change at short notice.
More compatible models will follow in this list for this cooler. We are currently checking other PCB designs from various manufacturers!
G.Skill enters the CPU AIO cooler market with its announcement of the new ENKI series liquid coolers. Custom designed with a convex copper cold plate and high-density radiator, the ENKI coolers are engineered for extreme performance. The new ENKI will be available in 240 mm, 280 mm, and 360 mm sizes. Pricing has not been announced yet so be sure to watch for future articles about this development. Continue reading for G.Skill’s press release. Read More
Today from Alphacool we get the chance to look at a very new product to the market, the Eiswand. This is a standalone watercooling kit with everything you need to get started! This kit is even friendly to those with small factor cases, as the radiator/pump/reservoir are all external and contained in one housing. Enough banter, let’s dig in and take a look at this kit! Read More
Cooler Master is known for affordable cases that provide excellent airflow, with the potential for more airflow if you add fans. The N600 is a new Cooler Master case that has a number of promising features. Let us do a deep dive and explore this case. Read More
Discussion
