Table of Contents
Alphacool announced the Eisblock Aurora Acryl GPX-N RTX 3070 Founders Edition GPU water block today. As with all of the Eisblock Aurora series, this is a nickel-plated full cover block that is said to produce exceptional cooling performance. A backplate is included to add stability and improve the overall aesthetics.
With the vast number of available GPU water blocks in the Eisblock Aurora line-up, it is obvious that Alphacool is committed to providing all of your custom water cooling needs, regardless of which GPU you are able to acquire. MSRP for the Eisblock Aurora Acryl GPX-N RTX 3070 Founders Edition GPU water block is $161.14. Here is Alphacool’s latest press release.
Alphacool Eisblock Aurora Acryl GPX-N RTX 3070 Founders Edition with Backplate
Alphacool presents a new Eisblock Aurora Acryl GPX-N cooler for the RTX 3070 Founders Edition graphics cards. The block offers outstanding cooling performance thanks to the full cover design. The new backplate, which is included with the coolers, also contributes to this. This stabilizes the graphics card and ensures an even contact pressure of the cooler. The cold plates are made of solid nickel-plated copper. The coolers cover all relevant components such as voltage converters and the graphics memory.
Data Cooler L x W x H 122,5 x 169,5 x 24,5 mm Material cooler Nickle-plated copper Material cooler top Acryl Threads 4 x G1/4″ Thickness cooling fins 0,6 mm
Data Backplate L x W x H 98 x 169,5 x 6 mm Material Aluminum Color Black Compatible with:
– NVIDIA Geforce RTX 3070 Founders Edition
MSRP: 130.99 € ($161.14)
Recent Articles
- Lian-Li Announces UNI Fan SL140 and Strimer Plus Triple 8 Pin GPU Cable
- Alphacool Releases Four New Eisblock Aurora GPX-N Coolers for 30-Series Graphics Cards
- G.SKILL Announces ENKI Series AIO CPU Coolers
- Alphacool Announces Eisblock Aurora Acryl GPX-A RX 6800(XT)/6900XT PowerColor Red Devil GPU Water Block
No replies yet
Loading new replies...
