Table of Contents
Alphacool has released the Core 120 mm and 140 mm PWM fans. They each offer three different models with speeds up to 4000 RPM for the 120 mm and 3200 RPM for the 140 mm version. Alphacool Core PWM fans feature a double ball bearing design and lack RGB lighting making them perfect for enthusiasts who abhor the rainbow glow. Pricing starts at just $6.73 making them highly affordable too. You can purchase them directly from the Alphacool website by clicking this link. Below is the official press release.
Alphacool Core 120mm and 140mm PWM Fans
It’s getting Windy!
Alphacool Core PWM Fans
Alphacool’s fan lineup gets a new addition! The quiet and efficient Core PWM fan is now available in 120mm and 140mm, each in 3 different speed variants. The 120mm version is available with a maximum speed of 2500rpm, 3000rpm as well as 4000rpm. The 140mm version is available with maximum speeds of 2000rpm, 2500rpm and 3200rpm.
The fan, which can be controlled via PWM signal, is not only suitable as a fan on CPU coolers or radiators. Thanks to its excellent performance values (throughput & static pressure), it can also be used as a case fan. The double-bearing fan axis (>2500rpm) is smooth running and allows for a long service life as well as quiet operation.
If you are looking for an affordable and powerful fan without aRGB illumination, you will find it with Alphacool’s Core PWM fan!
Features overview
– available as 120mm or 140mm version
– high airflow & static pressure
– wide speed control range using PWM
– durable smooth running bearing for quiet operation
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
On the heels of the 3090 Ti release, Alphacool announced its latest GPU water block, the Eisblock Aurora Acryl GPX-N RTX 3090TI Founders Edition with an active backplate. Designing a cooler for the world’s most powerful graphics card ever, the Eisblock Aurora utilizes a full cover copper cold plate with clear acrylic and addressable RGB lighting. Also available is an optional backplate with active cooling and an MCX adapter to connect it all together. But wait! That’s not all. A dual-slot mounting plate is included with the water block reducing the overall size of the GPU. Below is Alphacool’s press release with pricing and additional information.
Noctua has released the NF-A6x25 5V fans. Unpacking the numbering system a bit, that means they are 60 mm fans that operate at 5 volts. They come as 3-wire voltage-controlled and 4-wire PWM fans that are 25 mm thick. Cute little ol’ things, you say? Well, as we see smaller and smaller form factors, this kind of fan should find great use. So let’s check out these little fans and see how they do.
Alphacool’s Eisblock Aurora Acryl GPX-N series GPU water blocks continue to grow with four new additions. The new blocks expand the line-up for the RTX 3070/3080/3090 graphics cards. All four feature full coverage nickel-plated copper with an acrylic top and an included backplate. Pricing starts at $156 with immediate availability. Specs and prices are included in the Alphacool press release.
Discussion
