Table of Contents
Today, the German-based company Alphacool released the Eisbaer LT 92 SFF AIO CPU Cooler. The LT 92 SFF is designed to fit in small form factor cases with its small 90mm radiator. The details from Alphacool are found below.
Alphacool Eisbaer LT 92 CPU AIO
The Eisbaer LT 92 is the little sister of the classic Eisbaer LT. It is without quick release fasteners and is delivered with only 25 cm long hoses. This ensures it fits perfectly into SFF cases. SFF stands for “Small Form Factor” and describes extremely compact housings. Despite its small dimensions, the 92 mm copper radiator offers enough cooling power for powerful processors. Alphacool uses hoses and fittings from the Enterprise Solution series for the Eisbaer LT 92. The TPV hoses are particularly robust and do not kink as easily as the usual PVC hoses. Bend protection is therefore not necessary. The Eisbaer LT 92 is compatible with all mainstream sockets, the appropriate mounting material for various Intel and AMD sockets is included, also a set of fan screws for 25 mm fans. Fans are not included with this unit and must be purchased separately.Radiator Data
L x W x H 134 x 90 x 30 mm Material: Cooling fins Copper Material: Prechambers Copper Material: Chambers Copper Material: Threads Brass Threads 2 x G1/4″ Pump/Cooler Data
L x W x H 69 x 69 x 39 mm Material cooler bottom Nickle plated copper Material outer housing POM Threads 2 x G1/4″ (+ 1x Fillport G1/4″) Pump DC-LT Pump speed 2600 rpm Lift height 0,85 m Max. flow rate 70 L/h Voltage 12V Power consumption 4W Socket compatibility:
Intel: 775 / 1056 / 1155 / 1150 / 1151 / 1200 / 2011 / 2011-3 / 2066
AMD: AM2 / AM2+ / AM3 / AM3+ / FM1 / FM2 / FM2+ / AM4Price and Availability
With this release, the Eisbaer LT 92 is available to purchase through the Alphacool store for € 73.09 ($86.87 USD).
Loading new replies...
