I c, well this is what I've tried so far,
at 2/2/2/6 @ 175 fsb = bsod @ xp loading status
at 2/3/3/6 @ 175 fsb = hang @ xp loggin screen
at 2.5/3/3/6 @ 175 fsb = I'm running sisoft sandra right now.
but 2.5 on the Cas latency is no good, correct? I should try upping the sdram (APD) from 6 to 7... instead. Sorry for all the newbie question about ddr, I'm so used to my rdram setup
I figured 433mhz xms ram should be able to handle 450mhz no problem, so far I've been completely wrong unless I up the dimm vcore to 2.9. btw all my current testing is done with auto dimm vcore, which in turn will not go over its 2.7v spec, I assume
*edit* heh, well I just looked at the corsair xms3500 pdf spec and noticed the timings are 2-3-3-7... it doesn't list the dimm vcore though.. wish I had a official word if it was 2.7v, I've read from a few different posts 2.7, 2.75 and 2.8 :/
*edit* Melon_stunner: yes I'm running the latest drivers, btw what are you currently running your 2.4b @? You've posted so many awesome OC's curious to know what you've settled at for everyday use.
Maybe I'm pushing to high, I can run stable at 170fsb/425mhz ddr, 2.70 dimm vcore w/ 2,3,3,7.
or like I said if I push the dimm vcore to 2.9 I can run 180fsb/450mhz ddr, w/ 2,5,5,5.
Also I see your able to run your xms3200 at 2.8v, which bothers the hell out of me since my dimm vcore options are only 2.5, 2.6, 2.7 and 2.9, just totally skips 2.8v! thats why I was saying maybe I should switch to your epox board.
