ThePunkGeek said:
hmm gonna bore out a hemi and build it inside ? i didn't think so...
Sort of....
Back before I got into 'puters, I was into cars. Ever been in one of those hot rod parts shops, where they have an engine sitting on a stand in the corner, all decked out with chrome goodies, etc??
Well, I recall seeing somewhere back then, of a company that made dummy engine blocks out of foam, that you could bolt all the chrome doo-dads onto...looks like a real engine block (very detailed casting), but weighs very little. I've got a mess of Small Block Chevy stuff here...aluminum finned valve covers (OEM) for the early Z/28's and Corvettes, new timing cover, oil pan, etc...
Hollowed out, there ought to be plenty of room in there for everything, including H20. I could probably put the pump in the oil pan before bolting it to the foam block, and route the filler/burp tube out the "distributor hole" in the block... Lift off the intake manifold for access to the board/CPU, cards, etc...
Modify The SBC timing cover to hold a 120mm intake fan, centered over where the camshaft sprocket would be...do something similar on the back of the block, where I'd likely mount the radiator as well (6" x 6", with a 120mm fan), and the PSU.
I've gotta track down the company that made these (if they still do), and go from there... It'd be mighty interesting looking, I think...
