Hello guys, i'm new here
I want to know why my CPU and my GPU are always way too hot.
The GPU has been undervolted and little bit oced but still hitting 90°c (1010 Mhz @ 1.145 v, fan speed 100% always!) 60°c Idle 100 % fan
The CPU usually stays around 50 °c at idle (package temp from the RC Bluetooth app says 44°c) but when i pump Prime95 or IntelBurnTest the hottest core can reach 95°c that seems a bit too much... CPU is Oced at 4 ghz (135x30 @ 1.25 v) even at stock it reaches 90°c... and yes the CPU and the GPU have been repasted well and the room temp is at 27°c with air condition. The case has 2 4000 Rpm CPU fans in the front sucking air in and 2 cheap chinese PSU fans on the top blowing out. A small fan on the LSI Raid Controller and the classic stock fan in the back pulling out, plus a small server fan (the ones that are really noisy) mounted on the stock intel dissipator pulling air from it and sending to the top fans.
Any help to lower these temps??
Thx Francesco.
HD7990 - i7 990x - Rampage 3 Extreme - 24 gb ddr3 1600 Corsair LP - LSI Megaraid 9260-8i raid0 2 sas cheetah 15k7 - AX1200i (overkill )
Thx Francesco.
